VOTE, When to replace LAC? best aftermarket brands ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redtaco777, Jul 17, 2025.
  1. Jul 19, 2025 at 4:38 PM
    Redtaco777
    Redtaco777 [OP] Well-Known Member
    NC
    Uni-filter Mod
    Are all of these the ones that I need
  2. Jul 19, 2025 at 4:38 PM
    Redtaco777
    NC
    Uni-filter Mod
    So confused on why there’s 3 different size bolts
  3. Jul 19, 2025 at 4:38 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Bushings are part of the LCA.
  4. Jul 19, 2025 at 4:41 PM
    ZColorado
    13 DCSB OR 6MT
    I THINK you just need a 48409, and a 48190 per side. The rest can be removed and reused as long as they are in decent shape. please verify before you buy parts. I can’t easily verify where I am at the moment.
  5. Jul 19, 2025 at 4:44 PM
    Redtaco777
    NC
    Uni-filter Mod
    Damn these are expensive if get all 8
  6. Jul 19, 2025 at 4:46 PM
    Redtaco777
    NC
    Uni-filter Mod
    How likely do you think that mine are seized truck only has 80k miles :(
  7. Jul 19, 2025 at 4:58 PM
    Redtaco777
    NC
    Uni-filter Mod
    This is what my lcas look like
  8. Jul 19, 2025 at 7:47 PM
    Keaton1717
    Keaton1717 Well-Known Member
    Keaton
    New Richmond, OH
    Cement 2020 DCLB TRD OFFROAD/MGM 2014 ACLB TRD OFFROAD
    By looking at the small amount of rust on the LCA’s and on the back of the brake/dust shields I’d say 97% chance they are seized.
  9. Jul 20, 2025 at 4:18 PM
    ZColorado
    13 DCSB OR 6MT
    Yeah, if those aren’t seized I’d suggest they buy a lottery ticket.
  10. Jul 21, 2025 at 1:15 PM
    Redtaco777
    NC
    Uni-filter Mod
  11. Jul 21, 2025 at 2:29 PM
    Redtaco777
    NC
    Uni-filter Mod
    I will be upgrading my uca and adding bilstiens to my Tacoma &
    I want your honest opinion if this were your truck;
    Im debating on only buying the cam adjuster bolts(in case they are seized) OR going ahead and replacing my LAC as well….if I do buy new lac they will probably be after market(mavotech or freedom off-road)
    which aftermarket’ brands do you guys have good/bad experience with?
    Also do you guys recommend I get another bolt besides the cam adjuster that could potentially be seized or is it mainly the cam bolt ?
    I don’t want to spend unnecessary money if I don’t have to ..right now my truck is a 2012 sitting on 80k miles.
    should I replace my lac or leave them ? Please vote
  12. Jul 21, 2025 at 2:30 PM
    Redtaco777
    NC
    Uni-filter Mod
  13. Jul 22, 2025 at 5:49 AM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    My vote is to replace everything. OEM hardware and lower control arms (LCAs) are the best choice when it comes to quality and longevity. That said, if you're looking to save some money, I totally understand. Just keep in mind that aftermarket arms may not last as long as OEM—typically, you can expect around 50,000 miles before the ball joints start to develop play.
    If you're aiming for a more budget-friendly option, I'd recommend sticking with OEM hardware and going with a reputable aftermarket brand like Moog, Mevotech, SKP, or Centric. They’re all fairly similar in terms of performance. None of them stand out significantly above the others, but they’re solid choices for the price. If you can squeeze it I'd really suggest OEM LCA's simply because you won't have to worry for for easily 150k - 200k miles.
  14. Jul 22, 2025 at 11:51 AM
    Redtaco777
    NC
    Uni-filter Mod
    do they look like I should replace them to you ? If possible I wish I could just change out the hardware and keep my lcas.....also what about freedom offroad have you heard about those at all? I dont really want a greasable lca because I dont want them to fail incase I forget to grease them?
  15. Jul 22, 2025 at 1:52 PM
    #35
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    The main issue isn’t how the arms look - it’s whether the cam bolts are rusted and seized inside the inner sleeve of the bushing. If that’s the case, they’ll likely need to be cut out, and at that point, you’ll be forced to buy new control arms. No way around it.
    It really comes down to what you’re willing to risk. You could try replacing just the ball joints and picking up new hardware, hoping that you or the shop can remove the old bolts without too much trouble, and that the sleeves aren’t so corroded that it affects proper alignment. Or, you could just play it safe and replace the arms entirely, especially since a lot of guys on this forum (myself included) have had issues with rusted bolts getting stuck in the sleeves.
    Unfortunately, I don’t have personal experience with Freedom Offroad arms, but from a quick glance, they look decent and would definitely be an improvement over your current setup. I know it seems like a big job but it's really straight forward on Tacoma's and with fresh bushings and ball joints your truck will feel much tighter and direct, you'll be happy.
  16. Jul 24, 2025 at 1:10 PM
    #36
    Suarezabraham
    Suarezabraham Active Member
    Monterey, CA
    2014 Tacoma double cab 4x4
    What brands u guys recommend for replacement LCA I need mine done thanks
  17. Jul 24, 2025 at 1:17 PM
    #37
    Redtaco777
    NC
    Uni-filter Mod
    im going with freedom off road most likely bro I don’t wanna have to re grease my ball joints
  18. Jul 24, 2025 at 1:17 PM
    #38
    Redtaco777
    NC
    Uni-filter Mod
    if u can afford oem I would definitely do that tho
  19. Jul 24, 2025 at 6:13 PM
    #39
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    I’m overhauling the suspension on my truck right now and just replaced the lower control arm bushings and ball joints.
    You’re in NC so your alignment cam bolts might “not” be seized in the bushing sleeve. Mine were and I cut them out. A lot of my hardware was still in good condition, be it a little surface rust that was cleaned up with a wire wheel.
    That said you won’t know what hardware needs to be replaced until you remove your arms. I was surprised also by the price of the OEM hardware.
  20. Jul 24, 2025 at 6:21 PM
    #40
    Redtaco777
    NC
    Uni-filter Mod
    I actually I might , my truck might have came from up north
