VSC and ABS after Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clayhopkins1, Dec 9, 2015.
  1. Dec 9, 2015 at 7:30 AM
    clayhopkins1
    clayhopkins1 [OP] Honey_Badger
    DAVID
    ST PETERSBURG
    Morimoto 5K, Spidertrax 1.25", 265/75r16 BFG KO2s on black TRD wheels, Bilstein 5100s front at 2.5" and 1" block rear with 5160s, SOS Concepts Hybrid bumper, Warn M8000 synthetic, Trail Recon 22" Light bar, Walmart slim profile LEDs (as reverse lights), All alpine interior audio with Navigation, LED interior lights, "trailer plug" mod, locker mod, fog light mod, Debadged everything, custom sheet metal stiffener for tailgate, Cali Raised ditch brackets w/ Rigid Pods, firestik 4' antenna, cobra handheld cb (currently broken), Amazon (S-Pod clone).
    Hey guys i've looked on here and i've found some info but nothing that really pertains to my situation. I currently have a 3" lift on my 2015 Tacoma Double Cab 4.0 v6 TRD offroad and i got a 1" Toytec bodylift installed this past weekend and the guys didn't modify the wheel speed sensor wire bracket in the engine bay. I was driving home and then the VSC and ABS light came on and i looked under the hook and one of the wires got pulled out of the plug connector. The plug part # is 11002 or #11005 i cant remember the last number. The sensor wire is on the passenger side. I don't know how to disassemble the plug but i spliced the wires together but the lights are still on. Can anybody tell me what to do next. i really don't want to buy a new wiring harness from toyota. Is there a way i can clear the codes or something. Any help or guideance to a post i cant find would be appreciated guys
  2. Dec 10, 2015 at 4:46 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
  3. Dec 10, 2015 at 5:12 AM
    CroResident
    CroResident Well-Known Member
    Nick B
    Opelousas, Louisiana
    2015 4X4 DCSB
    6" Zone lift 35x12.50 Super Swampers
    i had the same issue man. once the problem was fixed, the ONLY way i successfully got the lights to come off was to bring it to the dealer and let them clear the codes. cost me like $48 but hey, the lights are off now and everything is working just fine. sometimes you just gotta bite the bullet on this kind of stuff
  4. Dec 10, 2015 at 5:15 AM
    Large
    Large Red
    My VSC has come on a couple of times after modifying the suspension, the lights went away after I had an alignment and disconnected / reconnected the battery
  5. Dec 10, 2015 at 5:18 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
    Ok yeah i tried disconnecting the battery but it's still there and ok i'll take it by there and see what they will charge for it. My buddy also mentioned resetting the trucks computer but i don't wanna have to go through the hassle of that.
  6. Dec 10, 2015 at 5:22 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    keep us updated
  7. Dec 10, 2015 at 5:24 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
    will do man
  8. Dec 10, 2015 at 5:24 AM
    TacoVet
    TacoVet Well-Known Member
    Fred
    2013 Tacoma DCSB TRD OR
    Your gonna need 2 paper clips lol hang on I'll get it for you
  9. Dec 10, 2015 at 5:44 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
    also does anyone know how to take apart the Toyota sensor plug under the hood. I noticed there was a white tab inside the plug that would pull out about 1/8" but wouldn't come out of the plug and the two terminals were still locked in somehow. If anyone can point me in the direction of a manual or how-to it would be much appreciated
  10. Dec 10, 2015 at 5:45 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
    i'll take them! never know when you're gonna need them
  11. Dec 10, 2015 at 5:46 AM
    TacoVet
    Fred
    You want to do steps 4 & 5. The sst wire they're talking about are the 2 paper clips. Follow the directions. My light was the car with squiggly lines under it (vsc). Note ***** make sure you push the paper clips in all the way!!! Hope it helps bud. Pm me if you need any help
    CroResident likes this.
  12. Dec 10, 2015 at 5:48 AM
    TacoVet
    Fred
    When you get a chance send me a pic of the plug. I'll look into it and see if I can help
  13. Dec 10, 2015 at 5:50 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
    do i need a scan tool?
  14. Dec 10, 2015 at 5:51 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
    ok ill take a pic when i get out of classes
  15. Dec 10, 2015 at 6:06 AM
    TacoVet
    Fred
    Nope not for the vsc and as far as the abs you might have to disconnect the battery for 10 minutes and reconnect and that should clear that
  16. Dec 10, 2015 at 6:07 AM
    TacoVet
    Fred
    Of course once the wire if corrected.
  17. Dec 10, 2015 at 6:30 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
    ok for number 4 it says i need an "Intelligent Tester" what is it and is it required. also do you connect the paper clips and run them into the CG and TS wire. Lastly is the plug shown the OBDII port
  18. Dec 10, 2015 at 6:32 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    When you disconnected your battery, how long did you leave it disconnected?
  19. Dec 10, 2015 at 6:34 AM
    clayhopkins1
    DAVID
    ST PETERSBURG
    I don't recall, it was disconnected from the time i unbolted the air inlet to the truck and the blower to when i unattached the wheel sensor wire from the truck to take a look at it and then reassembly. So i can't be 100% since i didn't time it
  20. Dec 10, 2015 at 6:35 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    You can try disconnecting the battery again and leaving it disconnected for approximately 10-15 minutes. Doing this should clear the codes. If not, then you may have to take it to the dealer.
