VSC and ABS after Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clayhopkins1, Dec 9, 2015.
  1. Dec 10, 2015 at 4:05 PM
    #41
    clayhopkins1
    clayhopkins1 [OP] Honey_Badger
    DAVID
    ST PETERSBURG
    Morimoto 5K, Spidertrax 1.25", 265/75r16 BFG KO2s on black TRD wheels, Bilstein 5100s front at 2.5" and 1" block rear with 5160s, SOS Concepts Hybrid bumper, Warn M8000 synthetic, Trail Recon 22" Light bar, Walmart slim profile LEDs (as reverse lights), All alpine interior audio with Navigation, LED interior lights, "trailer plug" mod, locker mod, fog light mod, Debadged everything, custom sheet metal stiffener for tailgate, Cali Raised ditch brackets w/ Rigid Pods, firestik 4' antenna, cobra handheld cb (currently broken), Amazon (S-Pod clone).
    the lights that are on were just the car with the squiggly lines and the abs light and then after i did the paper clip thing the trac off light came on
  2. Dec 10, 2015 at 4:07 PM
    #42
    clayhopkins1
    DAVID
    ST PETERSBURG
    yeah that's what happened to mine but the wire actually got ripped out of the plug in the engine bay, so i spliced the wire but i guess im gonna have to buy a new one
    #42
  3. Dec 10, 2015 at 4:29 PM
    #43
    TacoVet
    TacoVet Well-Known Member
    Fred
    2013 Tacoma DCSB TRD OR
    http://www.toyodiy.com/parts/
    Check this for the plug, possibly for other parts. Enter your vin to search for parts instead of year make and model
  4. Dec 10, 2015 at 4:32 PM
    #44
    TacoVet
    Fred
    So another question did you "clear the zero point" and then do "zero point calibration"
  5. Dec 10, 2015 at 4:39 PM
    #45
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    same happened with mine when installing lift. the abs wire where it clips on to the upper control arm got stretched and lost contact. i took it to the dealer, they spliced and reconnected where it had been damaged and i was on my way. quick and easy fix..
  6. Dec 10, 2015 at 4:54 PM
    #46
    clayhopkins1
    DAVID
    ST PETERSBURG
    yes i did step 4 where you turn the ignition on and then put the paper clips in the two slots 4 + times in 8 seconds but the warning light didn't blink
  7. Dec 10, 2015 at 4:55 PM
    #47
    clayhopkins1
    DAVID
    ST PETERSBURG
    how much did it roughly cost for them to do this. my truck has the extended warranty but ik lift and tires tend to void warranties
  8. Dec 10, 2015 at 4:56 PM
    #48
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    $85 took about 2 hours
  9. Dec 10, 2015 at 4:58 PM
    #49
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    it's a really simple fix, but you know how the dealership is..they're gonna try and make shit sound complex. good luck and i hope you get it fixed soon.
  10. Dec 10, 2015 at 5:00 PM
    #50
    clayhopkins1
    DAVID
    ST PETERSBURG
    Ouch... Well that's not to terrible. I'm a little strapped on money so craigslist here i come lol
  11. Dec 10, 2015 at 5:04 PM
    #51
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    good luck :thumbsup:
  12. Dec 10, 2015 at 5:06 PM
    #52
    TacoVet
    Fred
    You gotta make sure the paper clips are all they way in. I found it helpful to use 2 paper clips. I'm trying to think about what I did and I don't think I could get it to blink with the 4x in 8 seconds. I did it as many times as I could in 8 seconds without dislodging the paper clips. Then I left them separated when recalibrating, still using 2 separate paper clips, held them together for recalibrating
  13. Dec 10, 2015 at 5:18 PM
    #53
    TacoVet
    Fred
    Sounds funny but if iirc the top of my head was pointing toward the brake and gas pedal on that leaves you looking at the obd2 port the same way as the diagram in the instructions. Triple check you're in the right spots on the port ( use the slants or longer/shorter side or small square indents in the top right and left corner to indentify correct position). Now because you're using 2 paper clips, get out of the wheel well and I kinda leaned lightly against the door sill/jamb so I could watch the gauge cluster and touch the paper clips together at the same time
  14. Dec 10, 2015 at 5:19 PM
    #54
    clayhopkins1
    DAVID
    ST PETERSBURG
    ok ill re try that again and if not ill brain storm and think of something tomorrow and if not then ill just start to save some money on the side and call the dealership up and see if they can just "look" at it and give me an estimate
  15. Dec 10, 2015 at 5:24 PM
    #55
    TacoVet
    Fred
    I'll tell you what give it a couple solid tries tonight and if you can't I'll pm you my number and maybe we can do a step by step thing. When I did this I called I believe 3 or 4 dealerships and one knew what I was talking about and 3 didn't. One of the dealerships actually asked me for a copy of it. But the cheapest I was quoted was 65 bucks. I'm tellin ya I didn't give up that easily neither should you. Let me know what happens tonight and be thorough bud!
  16. Dec 10, 2015 at 5:26 PM
    #56
    TacoVet
    Fred
    You have to take into consideration that again iirc with the vsc being jacked up (out of calibration) it might affect driveability
  17. Dec 10, 2015 at 5:28 PM
    #57
    vrod671
    Brandon
    2022 TRD Sport
    Stock
    I've heard this too. I drove around for about a week and a half before taking it in to get fixed. Nothing happened, but it's always good to be safe.
  18. Dec 10, 2015 at 5:38 PM
    #58
    clayhopkins1
    DAVID
    ST PETERSBURG
    ok i got step 4 to work but when i do step 5 it doesnt do the blink on the vsc light. i connected the two paper clips before i turned the key to on but nothing even after 20 seconds
  19. Dec 10, 2015 at 5:44 PM
    #59
    clayhopkins1
    DAVID
    ST PETERSBURG
    ok the abs light shuttered and then came back on but the lights are still on
  20. Dec 10, 2015 at 5:52 PM
    #60
    TacoVet
    Fred
    Gotta do step 4 again
