VSC and LSD quick Q about 4WD?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Jan 5, 2010.
  1. Jan 5, 2010 at 9:17 AM
    BSP4x4
    BSP4x4 [OP] Guest
    Took the truck out in the snow...I understand how everything works in 2wd...what about 4 hi and low?
    While in 4wd can only turn off and on the VSC, but can not use the LSD right?
    and in 4wd Low i can't use any of these features (unless i do the wire mod) right?
  2. Jan 5, 2010 at 10:43 AM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    yes to the lsd not working with 4 hi not sure about the other
  3. Jan 5, 2010 at 11:29 AM
    BSP4x4
    BSP4x4 [OP] Guest
    anyone ?
  4. Jan 5, 2010 at 3:10 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    This is a popular question... I got on here last month after getting the new Tacoma and not understanding the drive modes because the manual doesn't fully explain. See if my long signature below helps explain. The A-TRAC is a button by the cig. lighter on mine, but if you didn't get the Off Road TRD maybe you don't have and need to cut the wire? TRAC in H4 worked great in deep sand. A-TRAC is for L4, otherwise in low range you have normal open differentials.
