VSC + c1432
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigTex970, Dec 6, 2016.
  1. Dec 6, 2016 at 7:25 PM
    BigTex970
    BigTex970 [OP] Active Member
    2017 Tacoma TRD OR DCSB
    I was installing a bumper light bar and didn't get a chance to wire it up because it started snowing. I ran wiring for LED, but never hooked anything up. Got in the truck and "Check vehicle stability control system" was on the display and checking codes it gives me 1 fault: C1432. Not sure why this showed up and if it has anything to do with light bar. Truck runs and drives fine. Thoughts?
  2. Dec 6, 2016 at 7:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You might want to find out what the C1432 code is.
  3. Dec 6, 2016 at 7:32 PM
    BigTex970
    C1432 TOYOTA Steering Angle Sensor Power Source Voltage Malfunction
    This is what I find.
  4. Dec 6, 2016 at 7:33 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Did you unplug anything?
    You said you ran wire but never hooked anything up, maybe when running wire you knocked something loose.
  5. Dec 6, 2016 at 7:58 PM
    BigTex970
    ran LED wire for switch through firewall and zip tied. pulled p/outlet No 1 fuse and washer fuse to test with multimeter to confirm only on with ignition/ACC for anticipated add a fuse to switch. started snowing. replaced fuses and cleaned up. nothing connected to battery or switches. Didn't get that far. Can't think of anything that could have gotten knocked loose beside around the front bumper and that doesn't make sense to me.
  6. Dec 6, 2016 at 8:13 PM
    daddy_o
    Bossier City, La
    I would retrace my steps where wire was pulled through, make sure you put the fuses back in the correct spot, make sure you didn't blow a fuse, and look for any connectors along the route you ran wire, both sides of the firewall. It seems like it should be something simple, and you didnt have this problem until you ran wire for a light, so it seems to be the most logical step to take first. If all else fails, you may have to pay dealer to diagnose and repair.
    vinkon235 likes this.
  7. Dec 6, 2016 at 8:25 PM
    gr0ver
    gr0ver Taco Supreme
    Charleston, SC
    2017 MGM Tacoma TRD Sport 4x4 DCSB Manual
    You definitely either knocked a plug loose or you just happen to have gotten a sensor go bad. Find where that sensor and plug is a go from there.
  8. Dec 8, 2016 at 1:56 PM
    BigTex970
    So I didn't find any connection issues or obvious solution, so I took it in to Toyota and they scheduled me for appointment after Christmas. The code description for c1432 I found above wasn't what they mentioned. Still pulling that code though. Check engine light never came on but VSC light stays on.
  9. Dec 27, 2016 at 8:59 AM
    BigTex970
    Update. Blown fuse. Dtc c1432 steering angle sensor power source voltage malfunction. Recommended checking ECU-B no 2 fuse and ECU-IG no 3 fuse.
