VSC Issue with new 33" tires, Spidertrax and 3" spacer lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cehensley, Mar 19, 2012.
  1. Mar 19, 2012 at 4:02 PM
    cehensley
    cehensley [OP] Member
    Tacoma 2011 Crew Cab LB
    Leer 180
    Just got back from my Toyota dealership service center trying to determine if they know of any issues related to a strange issue I've recently noticed. Three different times now, all within moderate speeds I have felt something "kick-in" randomly and for no reason. The thing kicking in... something in my steering like someone quickly vibrated the steering column. I'm fairly certain the VSC has kicked in and even beeped. Problem is that three times lately that's happened when no wheels were at risk of slipping. Today when it happened aI was going 35 around a sweeping curve and suddently it seemed to activate in my front left tire and beeped 3 or four times rapidly.
    The dealership says there's nothing wrong because no warning lights are lit up so they didn't even run diagnostics. ABS seems to be working. But I'm pretty certain that one or the other front tire has done this to me 3 times now since doing my modest suspension upgrades. Has anyone heard of such a thing?
  2. Mar 19, 2012 at 5:17 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Go back to your dealer, ask them to perform a zero point calibration. It may or may not help you. But do to the mods you have, vsc may *think* you are slipping, and activate itself. Probably to do with cornering and the wheel speeds picking up different then engine/vehicle speed. Hard to explain unless you understand all of the sensors involved.
    teamfast likes this.
  3. Mar 19, 2012 at 5:20 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  4. Mar 19, 2012 at 5:23 PM
    1GR
    Scott
    BC, Canada
    You should just be able to say zero point calibration, and they should understand. If they don't, find a new dealer. I do this on a regular basis to lifted Taco's, 4Runners, and Tundras.
  5. Mar 19, 2012 at 5:25 PM
    OZ-T
    Peter North
    British Columbia
    My dealer said there was no way to do it until I showed the tech the file from the above thread . Finding another dealer in my vicinity is not an option
  6. Mar 19, 2012 at 5:32 PM
    1GR
    Scott
    BC, Canada
    I deal with most of them at my dealer, so I don't ask for it. I already have that information. I don't know why your dealer is being so anal about it.
  7. Nov 18, 2016 at 9:58 PM
    urban
    urban Well-Known Member
    Norther Illinois / Southeast Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears (soaely missing 3.73's) Detroit true track Corbeau CR1 seats OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    I want to regear to 4.10's soon and 33's. Do you know what VSC/ABS problems this might cause me? Will there be disagreement between the power train senors and the wheel speed sensors or anything of that nature? How much can be done to adjust for these kinds of changes? I would be shocked if Toyota left any sort of provisions for this kinda stuff.
  8. Nov 18, 2016 at 10:23 PM
    Pigpen
    Pigpen A dirty little man
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Toyo M55 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 27F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, Cobra 75WXST cb with rear mounted Wilson 3' antenna on Shmellmopwho mount, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, 5100s with 885 coils and 1/4" spacers, SPC LR UCAs, 2wd low range mod
    The regear won't affect the ABS. The yaw sensor is calibrated for a stock vehicle. A lifted truck on bigger tires moves differently than a stock one, and the sensors read that movement as being a dangerous situation. The VSC pumps the ABS in an effort to "gain control", but really it's trying to pull you off the road.
    Follow Oz's advice.
  9. Nov 19, 2016 at 8:09 AM
    urban
    So this zero point calibration is a magical cure all?
  10. Nov 19, 2016 at 8:20 AM
    Pigpen
    Northwest Montana
    It establishes a new normal. So, in a sense, yes.
  11. Nov 19, 2016 at 9:15 AM
    OZ-T
    Peter North
    British Columbia
    Yes but it doesn't always work
  12. Nov 19, 2016 at 9:14 PM
    urban
    Then what does one do?
  13. Nov 19, 2016 at 10:39 PM
    OZ-T
    Peter North
    British Columbia
    I turn off the VSC at start up
