VSC? Lift? new Tires? Re-calibration? which one?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Elldogg, Nov 14, 2012.
  1. Nov 14, 2012 at 10:34 AM
    Elldogg
    Elldogg [OP] Elldogg
    Elldogg
    Santa Rosa, Ca
    '15 tacoma white 4x4 dcsb
    5100's 887 coils, icon tube uca's, magnaflow exhaust, afe cai
    Ok so i have heard a few differnt things about what to do and wanted to get an official verdict. i have a 2010 Tacoma access cab 4x4 trd with off road. I got the ultimate lift and terra grapplers (285/70/17) and i am having a problem when i get off the free way or on. My car starts beeping and the brakes for the front driver side start to come on. i know it is the VSC and i understand why, but i want to know the solution. here is what i have heard:
    option 1: go through the ECu and zerpo out the Yaw settings so that the copmputer can compensate for the new tire size http://www.tacomaworld.com/forum/691254-post.html
    option 2: 4wheel parts told me that i needed to have the speedodometer recalibrated and i would need to buy a box that will do that, of course they said that they would sell it to me and install it for a price.
    Option 3: hold down the VSC button(the car with the squiggly lines) for three seconds until the LSD light goes off and this will take off the VSC for the most part, but you have to do this each time you start the truck.
    I have tried the last option but i do not think i was going fast enough for it to engage anyways. so i will have to try it again ( i will update this thread when i do)
    i would also like to zero out the yaw settings and plan on doing that next, if there is any one who has had success with that(or anything else) let me know.
    Ps i live in Norcal (santa rosa) and if anyone wants to help out let me know. thanks
    my first post!
  2. Nov 14, 2012 at 12:38 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    #1 , and until you do #1 , do #3 , but you might still need to do #3 after you do #1
  3. Nov 14, 2012 at 4:15 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    welcome to tw!
    verdicts dont get much more official than oz around here, so you have your answer op!
    my vsc has gone off once randomly and havent heard a peep from it since. I dont know why thats even on our trucks at all tho.
  4. Nov 14, 2012 at 4:23 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I could be wrong but even if you do hold down the vsc button doesn't it just automatically come back on after a certain speed?
  5. Nov 14, 2012 at 5:02 PM
    OZ-T
    Peter North
    British Columbia
    No , that is if you press it , holding it down for 3-5 seconds turns it " off "
  6. Nov 19, 2012 at 9:50 AM
    Elldogg
    Elldogg
    Santa Rosa, Ca
    Thanks fellas, i am going to give that a try. I will probably take it to the dealship and give them the print out from the link above. Have a happy turkey day
  7. Jan 15, 2013 at 10:51 AM
    Elldogg
    Elldogg
    Santa Rosa, Ca
    I have tried all but option number 2 (i probably will not try that one) and they did not work. My best suggestion or current solution is to drive slow when going through on or off ramps. As long as you are not going too fast it will not lock up on you.
  8. Jan 15, 2013 at 10:54 AM
    OZ-T
    Peter North
    British Columbia
    You have pushed and held the VSC button so that the AUTO LSD and VSC lights come on , and after a few seconds the AUTO LSD light goes off , correct ?
    This should keep the VSC from acting up on you , but it still kicks on ?
  9. Jan 16, 2013 at 9:40 AM
    Elldogg
    Elldogg
    Santa Rosa, Ca
  10. Jun 14, 2015 at 11:52 PM
    juneatsbears
    juneatsbears Well-Known Member
    Jun
    Phoenix AZ
    Sorry for reviving this thread but has anyone come up with a legit and good solution to this. I am having the same problems as op. Tried looking for what I could do but cannot find much. Any help would be appreciated. Thanks
  11. Jun 15, 2015 at 12:15 AM
    OZ-T
    Peter North
    British Columbia
    Have you had your VSC zero point recalibrated ?
  12. Jun 15, 2015 at 11:12 AM
    Elldogg
    Elldogg
    Santa Rosa, Ca
    I have tried all of the above, and unfortunately none of it has worked. I heard that there are certain lift kits that don't mess with it, I have the toytec ultimate lift kit and mine still goes off, I just go slower around turns.
  13. Jun 15, 2015 at 11:15 AM
    Elldogg
    Elldogg
    Santa Rosa, Ca
    I heard that Les Schwab makes a lift kit that specifies whether or not you have VSC, they may be onto something there...
  14. Jun 15, 2015 at 11:16 AM
    Elldogg
    Elldogg
    Santa Rosa, Ca
    when you hold the VSC button for three seconds it turns off, but once you go above 40mph it automatically turns back on.
  15. Jun 15, 2015 at 11:27 AM
    OZ-T
    Peter North
    British Columbia
    Well kinda
    The light shouldn't come back on , if it does you didn't turn it off
  16. Jun 15, 2015 at 11:27 AM
    OZ-T
    Peter North
    British Columbia
    So you got an alignment , then had the zero point recalibration done ?
  17. Jun 15, 2015 at 12:27 PM
    juneatsbears
    Jun
    Phoenix AZ
    I installed my lift a while ago ( billies with eibach/toytec coils and icon progressive aal in the back) got that aligned. Didn't have this problem till this weekend, which is right after I got bigger tires. Running the same rims but new tires. Nitto trail grapplers, 285/70r16. So I'm pretty sure it's the tire. Truck scared the shit out of me yesterday when it happened.
  18. Jun 15, 2015 at 12:33 PM
    OZ-T
    Peter North
    British Columbia
    Yeah , it's not an enjoyable surprise
  19. Jun 15, 2015 at 4:35 PM
    juneatsbears
    Jun
    Phoenix AZ
    No kidding! Can't be good for the truck either. Been trying to replicate it all day on fm flat road and can't. Easy to do it on inclines tho. So I think I've narrowed it down to the new tires and the vsc sensor. Just need to figure out what I should do
  20. Jun 15, 2015 at 5:05 PM
    OZ-T
    Peter North
    British Columbia
    It's just like ABS , not going to damage the truck
