VSC Light after hitting trails
Discussion in 'Suspension' started by USACEPrkRngr, Jan 24, 2021.
  1. Jan 24, 2021 at 4:14 PM
    USACEPrkRngr
    USACEPrkRngr [OP] Member
    Isaac
    2011 Grey Tacoma TRD Sport
    K&N Intake, Full Boar cat-back dual side exit exhaust, Iron Man 4x4 3" suspension (coils, shocks, leafs), Iron Man UCA's, Helo 17x9" wheels 12mm backspace, 285/70-17 tires, black headlight assemblies (stock design, black backing), ditch lights.
    Just got done with a check-up on the ol' boy after some pretty gnarly trails yesterday. Think right side wheel bearing is starting to go and left side inner tie rod end is shot (think that's been a long time coming though, just replaced outers a few months ago).
    Biggest issue is my alignment. It's WAYYY out lol. Anybody running the total chaos alignment "taco" tabs?
    Follow up question, my stability control light is now staying on. I believe this is from the alignment issue. I'm thinking I'll wait until after I get an alignment to look further into it. Possible even doing a VSC reset after the alignment. Thoughts?
  2. Jan 24, 2021 at 4:30 PM
    sikTacos
    sikTacos Well-Known Member
    Eric
    SoCal
    2Gen Tacoma (DC/LB/4X4)
    Check your steering rack n pinion bolts as well. My VSC came on then I found an old TW thread where someone mentioned to make sure the bolts that go to the frame is tight. Sure enough after I went under to check and the bolts were unloose and was about to come off. Your truck may vary....
