VSC light won't turn off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Talltimber 12, May 14, 2015.
  1. May 14, 2015 at 2:30 PM
    Talltimber 12
    Talltimber 12 [OP] Member
    Hello - I have a 2013 Tacoma V6, sport double cab. Yesterday we were returning from a camping trip pulling our 20' trailer on the freeway when the VSC Indicator light up. It did not seem to affect the towing performance for the remaining 20 miles of our trip. I have read the manual and the various posts, including this one: https://www.tacomaworld.com/threads...rols-trac-auto-lsd-a-trac-rear-locker.212057/ , yet, I can not get the light to go off. I have followed the manual procedures to hold the button for 3 seconds, but no luck.
    Any suggestions on how to resolve this before I call the dealer to schedule an appointment?
  2. May 14, 2015 at 2:36 PM
    Nicks4x4LT
    Nicks4x4LT Official Villain
    Nick
    714 Orange county
    2010 4x4 V6
    Custom front bumper, Icon 2.5 ext. travel coilovers, Defined rear long travel King smooties w/ resi. Avid Offroad sliders, Fiberwerx front fenders, Glassworks Shorty TT style rear glass, URD MAF calibrator, DT shorty headers, URD TCAI, Magnaflow catback
    try disconnecting one side of the battery terminals, then report back :)
  3. May 14, 2015 at 3:54 PM
    Talltimber 12
    I disconnected the positive terminal for 60 seconds, reconnected and started the engine. VSC light was still on. Tried holding the switch for 3 seconds and light still stayed on.
  4. May 14, 2015 at 4:06 PM
    mike2810
    mike2810 Well-Known Member
    Arizona - Rim Country
    had 06 Sport 4x4 , now 2016 Nissan Pro 4x
  5. May 24, 2016 at 3:26 PM
    txtaco90
    txtaco90 Active Member
    isaac
    Orange County,CA
    12' prerunner dc sb
    was this problem solved?. I too have the same problem.....:confused:
  6. May 24, 2016 at 4:32 PM
    Talltimber 12
    Yes, it turns out that when towing my RV trailer it would cause the light to go on. I was using a tow bar system that was to tight, thus when the trailer was on, it would cause the the light to go. I had the tow bar system loosened up and that took care of the problem.
  7. Jan 31, 2019 at 9:42 AM
    Didy
    Didy Member
    Don
    2010 Tacoma 4 cyl standard
    2010 Access Cab, 2.7L 4x4 . I have this same issue. VSC light is on and stays on. I have tried the above thread and a few others. Light remains on. Any suggestions other than the tow bar?
    Light came on after the parking brake froze on. I needed to use 4 lo to get off the roadway. I suspect that this is what caused the issue.
  8. Jan 31, 2019 at 3:11 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Why not get the codes pulled?
    tcjacado likes this.
  9. Jan 31, 2019 at 5:04 PM
    Didy
    Didy Member
    Don
    Great idea. I found the codes, finally. Generic OBD reader does not pick up codes. Attached are the photos of the code text.
    I tried the resets in the thread above and it doesn't clear the light. Talked with the dealer and they state it must come in for diagnostics.
    Issue came up when truck "crabbed" when i was trying to break the brakes loose when they froze. I used 4 lo.
    Yes I know it was stupid but wasn't left with much of a choice.
    Any suggestions, solutions? Dealer may be only option but all dealers are 4 to 7 hours drive.
  10. Jan 31, 2019 at 5:12 PM
    Didy
    Didy Member
    Don
    Ok, code pictures did not come up.
    Codes are
    • C1336 Zero Point Calibration of Deceleration Sensor Undone
    • C1210 Zero Point Calibraton of Yaw Rate Sensor Undone
  11. Jan 31, 2019 at 5:13 PM
    Bebop
    Nick
    Lift the truck recently?
  12. Jan 31, 2019 at 6:53 PM
    Didy
    Didy Member
    Don
    Negative on the lift. Suspension is stock. Tires are standard. First time in 282,000 kM this came up.
  13. Jan 31, 2019 at 6:56 PM
    Didy
    Didy Member
    Don
    I feel the need to define "froze" in my earlier text. It was -30 C and brakes froze after being in heated garage for 4 hours.
  14. Jan 31, 2019 at 7:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    kbp810 likes this.
  15. Feb 7, 2019 at 5:49 PM
    Didy
    Didy Member
    Don
    Jimmy,
    I gave the procedure a try and still no luck. Light is still on. I may have to breakdown and take it to the dealer as this has irritated me so much I bought a 2013. Now I have to clear the warning light to be able to sell it.
    I appreciate your help. I am keeping that little gem in the glove box for the "next time"
    Thanks
    Didy
  16. Feb 27, 2019 at 12:45 PM
    Didy
    Didy Member
    Don
    The final outcome: I took the truck to a dealer and in 20 minutes they recalibrated the warning lights. I believe that because there is a calibration required, simply shorting pins will not rectify the warning light being on. Charge was $50. Well worth the 8 hours of driving to get there.
    Thanks for all suggestions.
    didy
    wilcam47 likes this.
  17. Feb 27, 2019 at 7:32 PM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    hold on, a warning light pushed you into buying a new truck? Yikes.
  18. Feb 27, 2019 at 7:34 PM
    Newfiebruh
    Tom
    *tire pressure light comes on* well fuck I guess it’s time to try a 3rd Gen. “but Jim you just need to add some air into the tir.....” “too late”
  19. Feb 27, 2019 at 7:45 PM
    Dirt Ferguson
    Dirt Ferguson Well-Known Member
    Daniel
    Napa Valley
    15 MGM DCSB TRD Sport
    KING 2.5 EXT, Total Chaos UCA, SCS F5, Katzkin
    Some people will use any excuse to buy a new taco, I guess. :notsure:
    Have fun!
