Vsc problems.
Discussion in 'Georgia' started by Barhopper, Mar 17, 2019.
  1. Mar 17, 2019 at 5:27 PM
    Barhopper
    Barhopper [OP] Well-Known Member
    Dustin
    Nw Georgia
    2010 Tacoma Sr5 Double Cab Long Bed
    King coil overs 2.5 with #650 springs, Spc UCA, OME Dakar standard leaf pack, extended Bilstein 5100, Pelfreybilt aluminum front and Pelfreybilt steel rear bumper.
    Anyone in the notrh west part of ga have access to what I believe is called a techstream. Having some horrible issues with the vsc kicking on around right hand curves. Fellow member suggested that I see if anyone has one to do a reset or zero point calibration to fix this issue. Any help would be greatly appreciated.
  2. Mar 17, 2019 at 5:51 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Is your Tuck lifted? Did this happen after you lifted it?
  3. Mar 17, 2019 at 5:57 PM
    TomTwo
    Bill
    I-85 Southbound
    @Barhopper there is a thread at the top of the 2nd Gen section on how to reset your vsc
  4. Mar 17, 2019 at 6:05 PM
    Barhopper
    Dustin
    Nw Georgia
    @TomTwo, I purchased the truck lifted. King 2.5 extended travel coilovers. About an 1 1/4 thread showing on the coilovers. Ome Dakar aal on the rear with extended Bilstien 5100’s.
    Long story short after I purchased it I put a new set of tires on it. Same size that was on it, 285/75/16. Had an alignment done at the same time.
    The day after is when all this started happening. I’ve tried the vsc reset that everyone said would fix it without any luck. Also had one shop say that could and did a vsc reset but I think they just cleared the code that the alignment machine said needed to be cleared. I got kinda use to getting in and holding the trac control button for a few seconds to turn it off and it hasn’t done it again till this weekend.
    Last week I did have lca bushings, uca bushings, new axles and new front and rear diff fluid installed. Had an alignment done after that to. Now the trac control button trick doesn’t even work. The vsc kicked on today around a curve and I thought I was hitting the car coming head on.
    TomTwo likes this.
  5. Mar 17, 2019 at 6:09 PM
    Barhopper
    Dustin
    Nw Georgia
    @EatSleepTacos, that’s the reset I’ve tried a bazillion times with no success. I get all lights flashing the way it says it should. Keep the truck still. Steering wheel straight. No luck. This has been going on now for a couple of months
    TomTwo likes this.
  6. Mar 17, 2019 at 6:10 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    check your wires, see if anything is loose/frayed etc to antiskid
  7. Mar 17, 2019 at 6:12 PM
    Barhopper
    Dustin
    Nw Georgia
    I was in all over those wires the past week. I looked and looked for anything loose or frayed. I can’t see anything wrong to my knowledge.
  8. Mar 17, 2019 at 6:12 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah I posted the link, then read your long post, and deleted it. Bummer it didn’t work for you.
  9. Mar 17, 2019 at 6:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    At this point I would just take it to the dealer and have them reset it. The price is worth your safety.
    TomTwo likes this.
  10. Mar 17, 2019 at 6:16 PM
    Barhopper
    Dustin
    Nw Georgia
    It’s cool. Thanks for the input. I’m open for any help at this point.
  11. Mar 19, 2019 at 2:58 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    I recently performed the VSC relearn after a steering rack replacement, and it worked for me:confused:
  12. Mar 19, 2019 at 3:01 PM
    HappyGilmore
    Huntsville, AL
    Yes
    Although I will mention that about a week later, after several miles of fairly quick gravel road riding, my traction kicked in twice in the middle of a curve exactly like you stated. Freaked me out, but hasn’t done it since.
  13. Mar 20, 2019 at 4:42 AM
    Barhopper
    Dustin
    Nw Georgia
    Yeah a lot of people say it works like a charm. A lot of other people say it does nothing. My luck though. Talked to a dealership yesterday in Cleveland tn and got me an appointment for Saturday. Said it would be at least 140 to do a zero point calibration. Sucks ass but I guess it will be worth it in the long run. I’ll update after I leave there.
    TomTwo and HappyGilmore like this.
  14. Mar 20, 2019 at 5:10 AM
    HappyGilmore
    Huntsville, AL
    Yes
    Bummer they are charging you out the ass for a service that will take them 10 minutes, but its also worth the peace of mind if it indeed fixes your issue. Absolutely keep us updated!
    TomTwo likes this.
  15. Mar 23, 2019 at 11:30 AM
    Barhopper
    Dustin
    Nw Georgia
    Well Toyota of Cleveland Tn has just told me the reason my truck does this is because it’s been modified. I asked if they performed a zero point calibration and they told me there was no reason to do that since everything was in spec. The only reason I drove and hour and a half to the dealership today was to have someone do that. Told me that it just something that comes factory on these trucks to keep you safe. Total fucking bullshit if you ask me. I’m done with Toyota. If anyone wants a real good truck with a vsc problem let me know. Fuck I’ll even deliver it to you.
    EatSleepTacos likes this.
  16. Mar 23, 2019 at 11:39 AM
    Barhopper
    Dustin
    Nw Georgia
    I can literally take a left hand curve at 100 mph and nothing happens. Take a curve to the right at 25 and it will about wreck the truck. Makes no sense at all
  17. Mar 23, 2019 at 11:40 AM
    tcjacado
    tcjacado Well-Known Member
    The steering/rack and pinion is off by a degree one way or another. You need techstream and possibly to fix the rack and pinion/steering angle.
  18. Mar 23, 2019 at 11:44 AM
    HappyGilmore
    Huntsville, AL
    Yes
    Contact ACC Garage and see if they have the tools to help?
  19. Mar 23, 2019 at 11:50 AM
    Barhopper
    Dustin
    Nw Georgia
    So that’s not something that the Toyota dealership does.
  20. Mar 23, 2019 at 11:52 AM
    Barhopper
    Dustin
    Nw Georgia
    And how could my steering rack and pinion be off. I haven’t had anything done to it. The outer tie rods is the only thing to my knowledge that has been adjusted on
