VSC recalibration, how many folks accomplish it
Discussion in 'Suspension' started by PMK, Jul 6, 2013.
  1. Jul 6, 2013 at 9:49 PM
    PMK
    PMK [OP] Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors
    With all the suspension mods done and posted about, I am curious how many people reset their VSC to account for the new baseline from suspension work or even alignment.
    PK
  2. Jul 6, 2013 at 9:52 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I have had it done three times , it worked the first two times
  3. Jul 6, 2013 at 9:54 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    With just a 2" lift i just had the alignment done... the vsc still works fine with no problems.
  4. Jul 7, 2013 at 3:15 AM
    PMK
    Florida
    10 DCLB TRD Sport
    How do you know that for fact?
    The tech pubs state a recalibration should be accomplished whenever the front end is aligned or the sensor is replaced.
    Just correcting the Taco lean should have it recal'd.
    Not bagging on you, just suspect it is more common not to recal which seems odd since it is a performance and safety item.
    PK
  5. Jul 7, 2013 at 3:49 AM
    bigtaco06
    bigtaco06 Well-Known Member
    Jared
    Nor-Cal
    13 TRD OR DBCB SB
    Floor mats, shorty antenna, brute force hybrid front bumper, ICON stage 3, method double standards, 285/75/16 KM2's, cool stickers
  6. Jul 7, 2013 at 5:59 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    When they did my alignment it was included. Their paperwork called it ESC but I assume it's the VSC. Their alignment computer tells them whether it's required or not. Guess it depends on how big of a change they make.
  7. Jul 7, 2013 at 1:54 PM
    OffroadToy
    4X4 Offroad
    I still have the same lean... don't care for the level look. The vsc comes on when needed just like it did before the lift... no difference.
  8. Jul 9, 2013 at 2:51 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    I haven't had mine recalibrated. it might go off randomly once a month, not a big deal.
  9. Jul 27, 2013 at 8:42 PM
    Rocknroll
    Rocknroll Well-Known Member
    Devin
    Ventura County, CA
    TRD Sport DCLB 4x4
    Put on a 3" lift and didn't reset VSC.
    What happens if it isn't recalibrated? Does it just turn off or does it affect handling?
  10. Jul 27, 2013 at 8:52 PM
    Super Black Taco
    Super Black Taco Well-Known Member
    Grayson
    Redwood valley, CA
    09 TRD SPORT 4x4
    OME 885 1/4 spacers,Dakars, 3* shims,Light Racing UCA BHLM,Wicked Flow Muffler, JL sub, Alpine amp, URD Short Throw Kit, U-Bolt Flip kit, 285/70/17 hankook mt
    I tried didn't work. If you live in the city its not a big deal. If you live in the mountains you are going to have a bad time. With that being said i pulled the fuse and have never looked back except i do miss my limited slip should of bought a 08 :facepalm:
  11. Jul 27, 2013 at 8:58 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged MT TX Pro
    2011 S/C Mid Travel
    its more susceptible to go off when it shouldn't. if i'm driving on a windy road or pulling into a shopping center driveway that's a little off camber it'll kick in. most daily driving situations, not recalibrating it shouldn't be a huge deal. and when not on pavement, the good ole abs kill switch turns all that nonsense off to keep it from interfering with the drive
  12. Jul 28, 2013 at 3:29 PM
    PMK
    Florida
    10 DCLB TRD Sport
    I started the topic after recalibrating mine. The process is super easy, requires a couple of thin wire paperclips and level ground.
    Took about five minutes from rolling in on level ground, centering the steering wheel, clearing the existing setup, recal and drive away.
    Almost seems silly not to accomplish if the system is still active.
    PK
  13. Jul 31, 2013 at 10:21 PM
    Rocknroll
    Devin
    Ventura County, CA
    TRD Sport DCLB 4x4
    Can you post how you recalibrated yours? Thanks
