VSC Switch on 07 Offroad
Discussion in 'Technical Chat' started by OffroadToy, Oct 12, 2009.
  1. Oct 12, 2009 at 4:48 PM
    OffroadToy
    OffroadToy [OP] old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The manual is a bit confusing concerning this button. Is the VSC Off Switch mainly used to free a stuck vehicle when in 2WD before relying on 4WD or the rear locker to get you out by useing the Auto LSD to apply brakes to the slipping wheel, thus giveing more torque to the wheel with traction? What are some other reasons to use this feature? Does the below operation of this switch sound about right...
    Normal Operation (2wd)... vsc on, trac on, autolsd off
    Push Once (under 62mph)... vsc on, trac off, autolsd on
    Push & Hold (with vehicle stopped)... vsc off, trac off, autolsd off
    Push Again (to return to normal)... vsc on, trac on, autolsd off
  2. Oct 13, 2009 at 6:25 AM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    I agree, I had to read and re-read that section in the manual quite a few times, and sometimes I still confuse myself!
    I think you have it right there.
