VSC, Trailer Sway Control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by savedone, Jun 23, 2013.
  1. Jul 28, 2014 at 7:47 PM
    #201
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No scotch mist for over a week
  2. Jul 28, 2014 at 7:50 PM
    #202
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    OME lift.
  3. Jul 28, 2014 at 7:55 PM
    #203
    OZ-T
    Peter North
    British Columbia
    Yes I have a lift but that's irrelevant to whether VSC can still engage in VSC OFF mode
  4. Jul 28, 2014 at 8:03 PM
    #204
    monkeyface
    Colorado
    The only times I've heard about VSC engaging outside of normal specs is from people with lifts.
    All of the documentation says when it's off, it's OFF no matter the speed. I've never had VSC engage unexpectedly. When I turn it off, it's OFF. Heck, you have the total disconnect switch you added, right?
  5. Jul 28, 2014 at 8:06 PM
    #205
    OZ-T
    Peter North
    British Columbia
    Here's the thing though , if it's totally off in VSC OFF mode , it can't come back on but it did , so that means it can come back on in VSC OFF mode , which means it's not totally off in VSC OFF mode
    You can't have it both ways
  6. Jul 28, 2014 at 8:09 PM
    #206
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Scotch will trip the VSC
  7. Jul 28, 2014 at 8:11 PM
    #207
    OZ-T
    Peter North
    British Columbia
    Speaking of documentation :
    I just wanted to clarify something for you guys. Despite VSC being disabled via the VSC off switch, it is in fact true that the VSC system can still engage but only for speeds above 30MPH and ONLY if your truck is skidding sideways, indicating a loss of control (Yaw Rate Large). Both of these conditions must be true in order for the system to engage.
    This all came about from a foot note in the brake technical document that was released when the 2009 trucks came to market. This foot note generated lots of discussion and debate. In an attempt too settle the discussion, I placed a phone call to Toyota. I've verified the foot note with a Toyota Drive Train Specialist who took my phone call back in 2009.
    To put this another way, yeah you disabled VSC, but know that it's monitoring the truck at speeds above 30MPH and can and will intervene if you have lost control or it believes you're about to loose control of the truck. :cool:
    http://www.tacomaworld.com/forum/2n...riving-questions-concerns-11.html#post6557364
  8. Jul 28, 2014 at 8:24 PM
    #208
    monkeyface
    Colorado
    Wheel sensor gone bad, shiner on one of the four wires, those are thin wires probably 22awg with thin insulation. They hang down onto some metal pieces from what I've seen. A little rubbing with that thin insulation and you could get a shiner. Intermittent problem.
  9. Jul 28, 2014 at 8:42 PM
    #209
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Towing me and some buddies dirt bikes, I had the VSC come on around a corner going uphill ? :p
    Wish I'd read this first! Haha scared me for a quick second.
  10. Jul 28, 2014 at 9:12 PM
    #210
    OZ-T
    Peter North
    British Columbia
    Just ignore this ~
    http://www.tacomaworld.com/forum/showpost.php?p=8968665
  11. Jul 28, 2014 at 9:25 PM
    #211
    OZ-T
    Peter North
    British Columbia
    X2
  12. Jul 28, 2014 at 9:42 PM
    #212
    monkeyface
    Colorado
    Post #162 on this thread, bobcape's contribution:
    Originally Posted by Bobcape
    We have plenty of snow on the ground and got new 5-6" last night so I figured I'd go try it out. Kind of hard to find a snowy parking lot though. Most places have them plowed already.
    I've only had my tacoma about 6 weeks or so. All this was in 2Hi. First, without any changes, I started from a standstill and punched it straight ahead. The VSC light came on and I could feel it kicking in. Cool. Then I clicked the VSC button once. VSC Off and Auto-LSD came on. I did the same thing, punched it straight ahead. A little more slipping but it still grabbed but more right, left, right, etc. than with the VSC on. The I put it in park and held the VSC button in. TRAC-Off displayed. I punched it straight ahead and it spun like my old Chevy 1500 used to.
    Then I did donuts in the 3 different states. VSC on - surprisingly good traction. I could definitely tell when it was kicking in. Single press of VSC button - not bad traction but less smooth when the LSD kicked in. More skidding. Last press and hold the VSC button, TRAC-Off - skidded all over the place. Even when I stopped accelerating it wanted to continue to whip the back end around. Lots of fun. I did probably 7 donuts like this. Some from start off and some after spinning one way and starting the other direction. In this short test the VSC did not re-engage. Not taking sides, just giving another data point.
    That says it all, good test with a new truck, DCLB. If one's truck is behaving differently, it's because it's been modded or there are some failures somewhere in the system.
  13. Jul 28, 2014 at 9:43 PM
    #213
    OZ-T
    Peter North
    British Columbia
    Can't be totally off if it can come back on
    Pretty simple concept
  14. May 6, 2015 at 1:17 PM
    #214
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    My truck's NEVER comes on. Ever. Even when its "OFF".
    I'll wait................
  15. May 6, 2015 at 1:22 PM
    #215
    Roll Tide
    Q
    01 T4R
    HOLY THREAD REVIVAL....(newb)
