VSC vs. larger tires (stock otherwise)...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Puppypolice78, Feb 12, 2013.
Have 265/75/16's caused VSC issues on your otherwise completely stock truck?
  1. Yes. 265/75/16's gave me VSC issues on stock wheels/susp./truck.
    1 vote(s)
    7.7%
  2. Nope. No VSC issues!
    12 vote(s)
    92.3%
  1. Feb 12, 2013 at 8:31 PM
    Puppypolice78
    Puppypolice78 [OP] Active Member
    NC
    4X4 2.7L
    I've searched and read threads until my eyes bled... Still can't pin down a definitive answer since most of those are running larger tires and having VSC issues are usually lifted/leveled/aftermarket wheels as well.
    I can get some 265/75/16's at a great price but don't want to take the plunge if there's any real chance of the VSC having a hissy fit with the slightly larger tire. These will be going on base 16" stock steelies. Suspension is completely stock.
    What say ye? 265/75's totally issue free on otherwise stock '09+ truck??
    PS: If this has already been covered and I missed it, apologies in advance...
  2. Feb 12, 2013 at 8:32 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Most people have no issues going up to that size .
    Having said that , my first VSC issues started when I was on 265/70/17 ( same size as 265/75/16 ) MT's before I lifted
  3. Feb 12, 2013 at 8:35 PM
    Puppypolice78
    NC
    4X4 2.7L
    Thanks for the reply... I've read a lot of your posts while researching this :). What wheels were you running when the issue started?
  4. Feb 12, 2013 at 8:37 PM
    OZ-T
    Peter North
    British Columbia
    Stock Sport alloys
    Funny thing with my situation is that I had the 265/70/17 Hankook MT's for about 6 months with zero issues until I got the Tranny TSB reflash done , from that moment on I had sensitive VSC problems
  5. Feb 12, 2013 at 8:38 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    I'd say your good to go. I'm running 265/75/16's with a 2" lift and have had zero vsc issues.
  6. Feb 12, 2013 at 8:39 PM
    Mark350
    Mark350 Well-Known Member
    I'm running 265/75/16 on FJ trail team wheels with stock suspension for about a year now with no issues.
  7. Feb 12, 2013 at 8:42 PM
    Puppypolice78
    NC
    4X4 2.7L
    Gotta say that experience is not making me feel all that great about the 265's... It seems that a lot of people think the VSC issue is also possibly related to differing wheel offsets, but apparently it happens with stockers too.
  8. Feb 12, 2013 at 8:44 PM
    OZ-T
    Peter North
    British Columbia
    Honestly , my issue is pretty rare , most people have zero issues going to that size
    I would do it
  9. Feb 12, 2013 at 8:54 PM
    Puppypolice78
    NC
    4X4 2.7L
    I suppose I could always just Cragslist them for a small loss (hopefully) if things didn't work out. I still would have felt better if this thread got 25 replies of people saying they had no issues. :)
  10. Feb 12, 2013 at 9:02 PM
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    09 TRD Offroad 4x4 - MGM
    Plethora of "useless" shit
    I've been running 265/75/16 BFG AT's for over a year with Bilstein 5100's at 1.75 and TSB leafs. No VSC issues.
  11. Feb 12, 2013 at 9:08 PM
    OffroadToy
    Why don't you add a poll to this thread
  12. Feb 12, 2013 at 9:14 PM
    Puppypolice78
    NC
    4X4 2.7L
    Exellent idea.
  13. Feb 12, 2013 at 9:21 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Not sure what people have already said in this thread.... but VSC has no preprogramed tire size... only thresholds inside its computer system.. so it should readjust for the bigger tire size. Maybe if you had different side front and rear tire sizes it would act up
  14. Feb 12, 2013 at 9:28 PM
    OZ-T
    Peter North
    British Columbia
    First time I've heard that
  15. Feb 12, 2013 at 9:33 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    I'm not sure, but it seems like it shouldn't matter if the tire is only an inch bigger.. (the265-75-16) The system would detect the tires as all the same size, acting basically the same as stock
  16. Feb 12, 2013 at 9:36 PM
    OZ-T
    Peter North
    British Columbia
    What about 33's ?
  17. Feb 12, 2013 at 9:38 PM
    jage
    jage Well-Known Member
    Franktown CO
    '010 Silver Double Offroad Leather/Sunroof
    Been on my truck for 25K approx. It's new to me but there don't seem to be any problems (except the tires are crap!)
    I feel like the difference in diameter is less noticeable than the difference in weight (45lb/tire) between P and LT, based on test drives. Still I can spit rooster tails on my dirt road all day and there seems to be no lack of power with the larger tires- just a less punchy feel.
  18. Feb 12, 2013 at 9:39 PM
    Puppypolice78
    NC
    4X4 2.7L
    From what I've learned about VSC in our trucks so far, is that it can be really finicky and things like people raising the front susp. just one setting with Billsteins is sometimes enough to make the VSC homicidally yank brakes while people are cornering. Bigger tires, while all the same size, are going to change the data input to those sensors. It's just a matter of whether or not it is typically enough to freak out the system.
  19. Feb 12, 2013 at 9:51 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    I mean that i don't know.. bigger tires make your speedometer register your speed as slower, so maybe it would not detect wheel speed changes as sudden as they realistically are? Making traction control think there is no problem. Hows that sound for my dyslexic self?
  20. Feb 12, 2013 at 9:52 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
