VSS manual trans location
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vitalzone, Jul 6, 2021.
  1. Jul 7, 2021 at 4:01 PM
    Vitalzone
    Vitalzone [OP] Well-Known Member
    Arizona
    2016 TRD OR 4x4 DCSB 6 spd manual
    -ADS coil overs with RR, and compression adjusters -ADS triple bypass rear shocks -Mcm UCAs -Deaver U402 stage 1 leaf packs -ADS bumps in the rear with Icon U bolt flip striker plates -Relentless Offroad U bolts -Wheeler superbumps in front -SCS 17" Ray 10s -285/75/17 BFG KM2s -Nitro 5.29 gears -Pelfteybilt armor front to back with HC rear bumper. T- case skid cut to fit Spec U exhaust. -RCI diff skid -Avid bed bars with basket holding spare. Poison Spyder 3-way strap. Hi-lift jack,and shovel mounted to basket. - SDHQ ditch light brackets with BD Squadron Pro spots. -BD Squadron Pro wide cornering in F. bumper. -BD S8 30" bar in F. bumper -Smittybilt 10k X20 winch -Factor 55 fairlead, and prolink -Switch pro 9100, with custom machined aluminum switch bezel. -BAMF grille insert -URD short throw shifter -URD Spec U exhaust cut over axle. Exhaust looks like it was fabricated by a blind child. -Suntek carbon XP 18% tint all around -ARB single compressor, mounted on Slee bracket. Lines to front, and rear bumper. -Rear diff breather mod,ran to bed cubby. -Ovtune 1.05 FOB 91 -Sprint-booster -Clutch accumalator delete mod -Hella Sharptone horns -Crown +4” extended brake lines, with modified factory brackets to fit lines. -Hypertech speedo calibrator -Custom pinstripes, and trail rash done by the beautiful AZ desert.
    I dont think there’s anything that can be done on the front with the GM dana 44 hub conversion. Ive been trying to contact several people with the xlt kit and swapped rear, no luck yet.
  2. Jul 8, 2021 at 12:30 PM
    Vitalzone
    Arizona
    Do the Toyota technical documents describe system function? Curious what makes you think 2 out of 4 sensors will average the speed, and allow speedometer function. Not doubting you, just want to know where I can find info. LSK long travel kit retains sensors. I might need to go that route.
