vsv abs help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sch0enne, Jan 13, 2009.
  1. Jan 13, 2009 at 8:02 PM
    sch0enne
    sch0enne [OP] Well-Known Member
    penticton British Columbia Canada
    03 Tacoma TRD
    bed lights, cobra 19 dx cb radio, flow pro muffler
    hello everyone.
    im looking for a little help here. i realize there is a mod to disable the vsc and abs system but i wasnt completely confident doing this myself so i looked at the fuse panel diagram in my manual and there where 2 fuses one labled "abs no.1 (50a) another abs no.2 (30a).
    when i removed both. abs, vsc and emergency brake lights came on and a high pitch beep came from the cab. when i went for a short 15sec drive it felt as though i was loosing the brakes completely. so i put the "abs no.1"back in and the beeping stopped all the lights that where previously on where still illuminated. I went for a drive and everything seemed good and the vsc and abs where disabled. I guess what im asking is this the same as doing the other mod just without the convenience of a flick of a switch?
    any help would be great thanks
  2. Jan 16, 2009 at 1:45 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    i think you mean vsc. but yea that sounds amazing! anyone else try it? coulda be onto something!
  3. Jan 16, 2009 at 7:26 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    WORKS! I just tried it on my buddies truck and it worked! SOOOO much better! thanks a lot man!
  4. Jan 16, 2009 at 8:06 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    For my own edification... what's the purpose of disabling the VSC and/or ABS?
  5. Jan 16, 2009 at 11:01 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    The vsc is for traction control, so if it's icy and your back end get's loose, it keeps you in line by transferring power and slowing the slipping wheel. but when your wheeling, sometimes you need some tire spin, but this limits that, so taking out the fuse let's you spin your tires and essentially may help get you unstuck in many cases. abs is just part of that so we deal with loosing it.
    This should be known as a cheap trick!
  6. Jan 17, 2009 at 1:05 AM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    I thought there is a button to disable the VSC? or does that just disable the LSD?
  7. Jan 17, 2009 at 9:23 AM
    Delmarva
    Tucson, AZ
    Thanks... :thumbsup:
