w.adventures GX470 build + Life’s adventures
Discussion in 'Other Builds' started by w.adventures, Jan 19, 2019.
  1. Aug 27, 2020 at 1:52 PM
    #261
    w.adventures
    w.adventures [OP] Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    FWD Xr
  2. Aug 27, 2020 at 3:28 PM
    #262
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    The aftermarket shop is inline with Denver dealer/aftermarket pricing. Little higher than the dealer but not much. That dealer you have there must have some extra slidey lube tryin to sneak that one by.
  3. Aug 27, 2020 at 5:07 PM
    #263
    w.adventures
    Nowheresville, SC
    Yeah, I was hoping for $800-1000 from private shop and $1200 from dealer. I changed a clutch on my Acura 2.2cl back in high school, tempted to change it myself just don’t have a lot of time with the home remodel.
  4. Aug 31, 2020 at 8:03 PM
    #264
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  5. Aug 31, 2020 at 8:18 PM
    #265
    w.adventures
    Nowheresville, SC
    fatfurious2[QUOTED] likes this.
  6. Aug 31, 2020 at 8:24 PM
    #266
    fatfurious2
    David
    Ashburn, VA
    yea I guess so. Hopefully nothing else goes wrong with yours or mine. My check engine light has not come back on, but I still want to do the IAC valve and shift solenoids... luckily they are under $50 for both. And I still need to replace the fender, but again, its like $37-42 shipped for one.
  7. Sep 2, 2020 at 5:28 AM
    #267
    fatfurious2
    David
    Ashburn, VA
    My friend said the Fit is running again. He loves it.. probably because his FJ80 gets 7mpg, and the Fit gets 40
    w.adventures[OP] likes this.
  8. Sep 2, 2020 at 7:32 AM
    #268
    w.adventures
    Nowheresville, SC
    I thought about your fit the other day. Bargain for him for sure! Yeah, my truck gets 10mpg and it only has 101k miles so I want to keep the miles off of it as well. It’s getting great use with the house remodel and yard work though.
  9. Sep 5, 2020 at 10:45 AM
    #269
    w.adventures
    Nowheresville, SC
    @fatfurious2 filled up the tank the other day, went 310 miles and used 10 gallons of gas. Way better than the truck!
    fatfurious2 likes this.
  10. Sep 5, 2020 at 10:47 AM
    #270
    fatfurious2
    David
    Ashburn, VA
    That's impressive! Im getting about 220 in my civic.
    Still fighting a P0302 cylinder 2 misfire.. but im thinking my spark plug wires are damaged, so ill replace those soon. It drives and no lights are on currently, so im happy for now
  11. Sep 11, 2020 at 9:08 AM
    #271
    fatfurious2
    David
    Ashburn, VA
    Spark plug wires fixed my idle issue! But i also discovered i have a valve cover gasket leak. Already ordered it because it was $9 on Amazon. It will be delivered tomorrow
  12. Sep 14, 2020 at 9:55 PM
    #272
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    I asked you about this awhile ago, but am getting ready to pull the trigger and had some questions.
    Which metal tech coil conversion is that? Stage 1 with lift coils? Do you know if stage 2 or 3 will work with bags inside?
  13. Sep 15, 2020 at 5:25 AM
    #273
    w.adventures
    Nowheresville, SC
    Stage 2 and you cut off 2 of the levels on the isolators to use with airbags. I also recommend the icon 2” coils.
    Gen1FTMFW[QUOTED] likes this.
  14. Sep 15, 2020 at 7:29 AM
    #274
    Gen1FTMFW
    Awesome. Do you know how the trimming affects the bags (i.e. some bags require more trim, some less)? I'm looking at 1" lift coils for the rear but wasn't sure if the stock height Firestone bags would work if I minimally trimmed the isolators or if I'd have to use the 2"-3" lift bags with maximum trim and minimal inflation.
  15. Sep 30, 2020 at 6:51 PM
    #275
    fatfurious2
    David
    Ashburn, VA
  16. Sep 30, 2020 at 7:03 PM
    #276
    w.adventures
    Nowheresville, SC
  17. Oct 18, 2020 at 5:09 PM
    #277
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
  18. Nov 10, 2020 at 12:56 PM
    #278
    Bubbles
    Bubbles Liquor and Whores
    Sunnyvale Trailer Park
    Bumping because GX
  19. Nov 10, 2020 at 1:03 PM
    #279
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    OP sux, prove me wrong.
    Bubbles likes this.
  20. Nov 10, 2020 at 1:05 PM
    #280
    w.adventures
    Nowheresville, SC
