W59 countershaft rear bearing play.
Discussion in '1st Gen. Tacomas (1995-2004)' started by dfarnsworth24, Mar 23, 2023.
  1. Mar 23, 2023 at 8:33 AM
    dfarnsworth24
    dfarnsworth24 [OP] New Member
    David
    98 Tacoma SR5
    I’m replacing the input shaft bearing on my w59 transmission (grinding noise in 1,2, annd third. Sometimes fifth gear and goes anway when Clutch is in) and noticed a lot of play in the rear countershaft bearing. The bearing sits inside the rear housing so I would assume some play is okay. I’m about to extend this trans job a couple days by ordering a replacement countershaft beating but I’m curious if it’s supposed to have a good amount of play.
    Thanks
