"waa waa waa" sound between 60-70 mph?
Discussion in 'Technical Chat' started by santacruzyota, Aug 15, 2011.
  1. Aug 15, 2011 at 10:53 AM
    santacruzyota
    santacruzyota [OP] Member
    Kyle
    Santa Cruz, CA
    07 SR5 4X4 Sport 6-speed
    I have noticed a loud waa waa waa sound coming from the rear end of my truck at around 60-70 mph, it only does it while I'm on the gas, if I let off it goes away. I noticed it will do it around 40mph around the same rpm range (2400-2600). So I'm assuming this isn't not a tire issue. Any advice? Getting sick of hearing the waa waa waa band in the back of my truck on my hour commute every morning. Truck has 118xxx on it. 07 tacoma 4x4 sport 6speed.
  2. Aug 15, 2011 at 11:01 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Is it the blond chick in the passenger seat? Mine makes that sounds sometimes. Seriously, it's probably a U-joint or carrier bearing on the driveline. Pretty easy fix if you are mechanically inclined.
  3. Aug 15, 2011 at 11:07 AM
    rcfreak201
    rcfreak201 Well-Known Member
    mine does the same thing, and also since i installed spindles i feel weird vibrations at that speed and nothings loose ive checked and tightened everything a couple times
  4. Aug 15, 2011 at 11:07 AM
    santacruzyota
    Kyle
    Santa Cruz, CA
    Haha! My girlfriend (who is blonde) will enjoy that post. Thanks, I will check it out!
  5. Aug 15, 2011 at 11:37 AM
    santacruzyota
    Kyle
    Santa Cruz, CA
    Also it will vibrate while under power from about 50-65....same issue?
  6. Aug 15, 2011 at 1:43 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Check the carrier bearing. Slide under your truck and grab the driveline. If it's sloppy the carrier bearing needs replaced. If you haven't greased the U-joints in a while and they're worn they will need replaced as well.
