Wait or Not on King suspension
Discussion in 'Suspension' started by Buckshank, Mar 13, 2017.
  1. Mar 13, 2017 at 8:24 PM
    Buckshank
    Buckshank [OP] Active Member
    Brian
    2006 Toyota Tacoma TRD Sport
    3" lift HID Headlights
    I have decided to get King suspension (2.5 OEM Performance Series), but do not that he mulah to buy both front and rear just yet. should i just buy the fronts for now? will i notice a difference? or wait and but both at the same time?
  2. Mar 13, 2017 at 8:29 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Worth getting the front and yes it will be night and day difference. You can't go wrong with King 2.5" :thumbsup:
    Fiend13 likes this.
  3. Mar 13, 2017 at 8:31 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Just say fuck it and order the fronts. That's the most expensive part of a lift anyways. At least that will be done with. You can always find a set of blocks for the rear for pretty cheap to run in the meantime until you order the rear shocks and AAL/leaf pack
    Lord Helmet likes this.
  4. Mar 13, 2017 at 8:33 PM
    Buckshank
    Brian
    okay thanks for the input my man:bikewhoops:
    Fiend13 likes this.
  5. Mar 13, 2017 at 8:34 PM
    Buckshank
    Brian
    i already have a 3" on it would that matter ?
  6. Mar 13, 2017 at 8:35 PM
    Fiend13
    Chad
    What kind of 3"? Spacers?
  7. Mar 13, 2017 at 8:35 PM
    Buckshank
    Brian
    I believe so
  8. Mar 13, 2017 at 8:37 PM
    Fiend13
    Chad
    I would take the spacers off and use the coilovers for the lift. If you combine the 2 you'll have a stiffer ride, need new upper control arms, and you can really fuck up you cv's due to the angle both lifts will put them at.
  9. Mar 13, 2017 at 8:38 PM
    Buckshank
    Brian
    thats good to know, so if i go with the 2.5s are they adjustable? would i still have a 3" lift?
  10. Mar 13, 2017 at 8:41 PM
    Fiend13
    Chad
    Yes. The king 2.5's should be able to adjustable from 0-3". Just keep in mind that with a 3" lift like that you may need aftermarket upper control arms to get your alignment back to perfect.
  11. Mar 13, 2017 at 8:41 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Just get the extended travel for the 3" lift. the standard travel is up to 2" It should come from the factory preset at 2" just adjust them to the desired height for the extended travel coilovers.
    Fiend13 likes this.
  12. Mar 13, 2017 at 8:44 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Many of the so called "3 inch spacer kits" will actually only give you 2.5 lift.
  13. Mar 13, 2017 at 8:45 PM
    Buckshank
    Brian
    Yeah i still want at least a 3" lift Ideal would be 4",any recommendations for control arms?
  14. Mar 13, 2017 at 8:46 PM
    Fiend13
    Chad
    If you want 4" look into maxtrac spindles if you 2wd. They give 4" of lift without have to change anything out. You'll still be able to use your stock shocks, coils, UCA's, etc.
  15. Mar 13, 2017 at 8:48 PM
    Buckshank
    Brian
    regardless im going to get Kings suspension and if i can only get up to 3" lift with the coilovers im okay with that. do you ride with kings?
  16. Mar 13, 2017 at 8:52 PM
    Fiend13
    Chad
    I don't. I just ordered the fox 2.5 coilovers so I'm waiting on those. I'll probably keep those at 1" of lift to start out with since I'm gonna install the 4" spindles as well. I already have light racing UCA's installed since I'm currently running the bilstein 5100's with eibach coils. I'm keeping the coils at 1" so I can have a softer and smoother ride. Plus, I don't want 7" of lift lol
  17. Mar 13, 2017 at 8:53 PM
    Buckshank
    Brian
    So if i get the maxtrac spindles and kings suspension, i would have a 4" lift? or should i switch out the control arms as well?
  18. Mar 13, 2017 at 8:57 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    If you are 2WD you can get 4" out of the spindles PLUS a couple with the king's and still have a nice ride.
    Fiend13 likes this.
  19. Mar 13, 2017 at 8:57 PM
    Fiend13
    Chad
    For that I think it depends. If you leave the kings at a 0" setting and get the 4" lift from the spindles then I don't think you will. Once you start adjusting the kings to get more lift then you may want to get some UCA's. If you get UCA's spend the extra money and get a uniball setup. I didn't and I regret it. I keep having to change out upper ball joints. On the uniball setups you don't have to worry about that.
  20. Mar 13, 2017 at 8:59 PM
    Arrogant Basturd
    Arrogant Basturd Active Member
    Albert
    2015 Black DCLB TRD Sport
    I pulled the trigger on some king 2.5 with adjusters (front and back) this past weekend.
    been saving up for over a year. maybe 2.
    i don't even have them yet. and i'm all giddy. i don't think i'll regret them one bit.
    (uca and extended brake lines as well)
    Lord Helmet and Fiend13 like this.
