wakeboard winch
Discussion in 'Off-Topic Discussion' started by Hambone155, Nov 2, 2009.
witch engine read down below first
Poll closed Dec 2, 2009.
  1. grey hound 11hp electric start
    2 vote(s)
    28.6%
  2. tecumseh 11hp pull start.
    5 vote(s)
    71.4%
  1. Nov 2, 2009 at 7:53 PM
    Hambone155
    Hambone155 [OP] Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    im an engineering student and im in the process of designing and building a winch for wakeboarding and snowboarding. because here in nebraska we have just as much time with snow on the ground as we do with warm enough weather to wakeboard.
    heres my delima.
    engine.
    11hp electic start grey hound engine 259.99 (harbor freight)
    or 11hp tecumseh. pull start. no gas tank 139.99 (smallenginesupplier)
    max rpm
    11 hp grey hound 3600prm
    11 hp tecumseh 3750rpm
    torque converter.....with a engine that is 11hp will i need one.
    one problem i think about is i do not think they make one big enough for the 7/8" shaft.
    witch engine should i go with?????
    one is over a hundred bucks cheaper and has high rpm max and the other has the electric start..........
    what would you do?
  2. Nov 2, 2009 at 7:54 PM
    SouthWhittierMetalWorks
    SouthWhittierMetalWorks Well-Known Member
    South Whittier, CA
    98 Tacoma SR5 4X4
    Sirius Satellite Deckplate Mod
    I think Harbor Freight's unofficial motto is "For when you absolutely, positively need to use a tool...only once."
  3. Nov 2, 2009 at 7:55 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I saw this on MTV the other night, it looked pretty sick. Wake skate winching.
    I would use the tecumseh over the "throw in the Habor" freight...
  4. Nov 2, 2009 at 7:59 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I've heard nothing but good things about Tecumseh...
  5. Nov 2, 2009 at 8:00 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  6. Nov 2, 2009 at 8:00 PM
    Hambone155
    omaha
    bitchen guys!
    thanks!
  7. Nov 2, 2009 at 8:02 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  8. Nov 2, 2009 at 8:05 PM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
  9. Nov 2, 2009 at 8:10 PM
    Hambone155
    omaha
    oh ive done a ton of looking around. i know i can build one for under about 600. witch im pretty sure is about 2k cheaper then theres!
    with the help of my pops (the guy who designed and patented the ford talgate ladder) im sure i can get it down the hitch is the only think im a little scared about
  10. Nov 2, 2009 at 8:11 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Winch? Snowboarding? I am lost!!! Big time!!! Explain why you would want a winch for your snowboard or wake board?
  11. Nov 2, 2009 at 8:21 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    I have run Tecumseh engines in all my go-karts those engines are really strong. Also there is many parts for them. For your torque converter question just buy the one that is rated for an 8hp. I made a mid travel go-kart with a 13hp Tecumseh and used a 8hp torque converter i had no problems so far.
  12. Nov 2, 2009 at 8:23 PM
    SACTOWN
    Greg
    So lost
  13. Nov 2, 2009 at 8:23 PM
    Hambone155
    omaha
    ok well heres a short version.
    wake board....to do stuff in ponds or creeks or the best!!! urban water areas! look at the gene leahy mall...its in omaha my city and our down town area. there is tons of stuff i want to do down in there!
    snowboarding. if you may not know there are no mountains near the east side of nebraska. theres also alot of urban stuff to do on a snowboard but i find it unsafe when your friends pull you into a rail or staircase. (i need to feel like im in control)
    with a winch you can let go but with a friend they let go of you.
    basicly its just a badass way to not own a boat and still get the job done!
    got one just can use it all the time. its a pain in the ass to go an hr to the lake after work. board for an hr and drive back! F THAT!
  14. Nov 2, 2009 at 8:26 PM
    SACTOWN
    Greg
    Ohhhhhhh. Never though about it like that.. Cool!!
  15. Nov 2, 2009 at 8:29 PM
    Hambone155
    omaha
