Wal-Mart ruined a KO2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jagergirll, Mar 12, 2017.
  1. Mar 12, 2017 at 8:32 PM
    jagergirll
    jagergirll [OP] Well-Known Member
    Sam
    Midwest
    4x4 RC
    OME Suspension ARB Bumper Rock Sliders BFG KO3's Camper Shell
    So It was in the 20's yesterday and I did not want to do my oil change. I went down to wal mart and had them do an oil change and tire rotation. Well the left oils rags in my truck spilled oil in the engine bag, spilled dif fluid all over my pumpkin and ruined the sidewall of my KO2 they gouged the sidewall down to the wire. I complained this morning when I saw the damage and luckily they are going to replace the tire. I only have about 7000 miles on them so that made me feel better. Now is 7000 miles in going to mess up doing a 5 tire rotation? Also I think I'm going to see if they will let me keep this one so I have two KO2 spares for my 4x4 trips.
  2. Mar 12, 2017 at 8:41 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Get what you pay for.... honestly, no one to blame but yourself choosing Walmart to work on your truck.
    If you're that OCD about getting scratches on your tire's sidewall, you'd probably be better off choosing a more reputable place to touch your "pumpkin."
    To me, the tires themselves are wear items, and like every wear item, are meant to get worn down or damaged. I don't think you'll have a problem with rubber wear with a new tire thrown in your rotation.
  3. Mar 12, 2017 at 8:54 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    jjsul and DustStorm4x4 like this.
  4. Mar 12, 2017 at 8:57 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    wait, whats wrong? they spilled oil on your tire? i have no idea what you are trying to say lol
  5. Mar 12, 2017 at 9:06 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    No they ruined the side wall they gouged the tire and chunks of rubber are now missing from the sidewall. I just noticed the picture wasn't the right one they damaged it down to the wire on the side wall.
  6. Mar 12, 2017 at 9:09 PM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Do they sell ko2s? I figured they would only sell garbage no name stuff.
  7. Mar 12, 2017 at 9:13 PM
    paranoid56
    San Diego
    14 double cab taco
    i am confused on the tire damage, they wouldn't touch the tire when just doing a rotation. did you have them dismount the tires too?
  8. Mar 12, 2017 at 9:16 PM
    Stig
    Brandon
    Ta no mo
    Its walmart... nothing further should be needed. :rofl:
  9. Mar 12, 2017 at 9:17 PM
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    lol damn. your lucky theres oil in your engine.
  10. Mar 12, 2017 at 9:17 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    I had my spare rotated in. I'm ordering new wheels soon so that won't be an issue in the future so all 5 will be the same.
  11. Mar 12, 2017 at 9:18 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    They sell KO2 but I purchased them at Sears but Sears in my town has closed.
    Stig[QUOTED] likes this.
  12. Mar 12, 2017 at 9:24 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    OP says they spilled diff lube on the rear differential (commonly referred to as pumpkin) probably while checking it to try and upsell a diff lube change. Walmart is definitely in the league of the quick lube joints where their workers are under trained with high turnover.So yeah, they suck. But when you ask for a rotation and end up with gashes in your sidewall well that's not ok or a normal wear issue. At least it sounds like they are making it right by replacing the tire.
    jagergirll[OP] and jjsul like this.
  13. Mar 12, 2017 at 11:02 PM
    Brecop
    Brecop Member
    Wallyworld. Really? DIY or find decent place. My experience with BFG- fantastic tire. Go to Discount Tire and have them prorate a replacement. They did this on a used KM2 that separated.
  14. Mar 13, 2017 at 4:46 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    It is unreal that a guy can't bring his truck to a place and have to worry about a simple oil change and tire rotation. The op should expect that a job like that can be done by a "service center". Thats why like most guys on this forum I do all my own work............
    Sethhm0106 likes this.
  15. Mar 13, 2017 at 4:50 AM
    GrandeChalupa
    GrandeChalupa Well-Known Member
    Cole
    Tampa, FL
    2013 SR5 SB 4x4 Pyrite Mica
    Stock
    Why the fuck would you want to use it as a spare if it was bad enough to demand they give you a new one? Shister
    Sacrifice, PackCon and solem22 like this.
  16. Mar 13, 2017 at 4:51 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Never knew Walmart did diff oil changes. hope they tourque the fill bolts right.
  17. Mar 13, 2017 at 5:07 AM
    Pigpen
    Dan
    Northwest Montana
    FTFY
    OP has shown significant prowess with a wrench in past posts. It was cold and she didn't feel like doing the work out in the cold. I've been known to do the same.
    At least the expensive issue is being resolved. Keep it as a spare if they let you - the tire should have lots of life left, but I agree they should replace it. The "tech" obviously took your truck "wheeling" in the back parking lot. Never use them for work again.
  18. Mar 13, 2017 at 5:09 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Mall-Wart living down to their usual standards!
    Pigpen likes this.
  19. Mar 13, 2017 at 5:20 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    Does OP know what the tires look like when they are stored under the bed? Walmart didn't do shit...
  20. Mar 13, 2017 at 5:24 AM
    sjwhitaker
    sjwhitaker Today Was A Good Day.
    Jake
    Berea, KY
    2010 DCSB TRD Offroad 6MT - Icon Stage 2 - 285/75/16 Falken AT3W
    Walmart sells most big name tires. When they price matched I would look all over for the cheapest online price (usually companies that stick you with crazy shipping at checkout) and then go to my local Walmart and have them price match with free site to store shipping. Worked like a charm, load them up and go to my local mom and pop tire shop for a mount and balance.:D
