Wal-Mart ruined a KO2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jagergirll, Mar 12, 2017.
  1. Mar 13, 2017 at 7:43 PM
    #61
    Pigpen
    Dan
    Northwest Montana
    The alloy wheel will be fine in the stock spare location. Op, you've been around long enough to ignore the idiot posts that always show up on these threads. I'm glad Walmart is replacing the tire for you.
    The change in hair color looks good. I hope you're doing well!
  2. Mar 13, 2017 at 9:29 PM
    #62
    Justinlhc
    Justinlhc Not looking for a relationship
    If you go on Walmart.com and search for a tire I bet they list it. The Wrangler Authority tire is a Walmart exclusive tire and it's received tons of positive reviews on here.
  3. Mar 14, 2017 at 4:04 AM
    #63
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    OP, it sounds like someone is hitting on you via the Internet! :eek:
    wake100 likes this.
