Walbro or Factory Denso fuel pump???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gincoma, Dec 18, 2010.
  1. Dec 18, 2010 at 9:04 PM
    Gincoma
    Gincoma [OP] Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Ok so my fuel pump is staring to take a dump. My truck has been running like crap lately and finally almost pinpointed it to my fuel pump. I have 136,000 mi so needs changing anyways. I was going to buy either walbro or factory denso. What would you guys suggest. Thanks.
  2. Dec 18, 2010 at 9:16 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    The Walbro kit from URD?
    Definitely.
  3. Dec 18, 2010 at 10:18 PM
    Gincoma
    Salt Lake City UT
    Ive seen that kit but its around 5 to 6 hundred dollars, I know walbros are good just not sure when compared to factory.
  4. Dec 18, 2010 at 10:22 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    The URD upgrade kit is $155. The Toyota replacement is around $600.
    If you are going to order it for the FJ, in the comments section let us know that so we can ship you the FJ version. One part is slightly longer for the FJ.
    G
  5. Dec 18, 2010 at 10:30 PM
    Gincoma
    Salt Lake City UT
    Awesome...is it basically plug and play or do I have to cut hoses. I heard the walbro fuel pump itself is a bit longer then the factory one making it so I have to cut that hard line about an inch for it to fit.
  6. Dec 18, 2010 at 10:31 PM
    Gincoma
    Salt Lake City UT
    Anyone else running walbro???
  7. Dec 19, 2010 at 5:52 AM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    Go for the walbro. I have run it in many applications where stock wasn't good enough or too expencive. I might purchase Gadgets kit soon myself.
  8. Dec 19, 2010 at 7:21 AM
    ZenkaiTaco
    ZenkaiTaco Well-Known Member
    Utah
    11 DCSB TRD OR
    I dont know how much the one for the Taco or FJ flow, but I'm running one in my 97 Eclipse. And its one loud mofo. Its a 255LPH High pressure unit, so maybe the ones for the Taco or FJ are quieter. But the walbros use metal gears in their pumps which are inherently louder from the start then the yota's plastic gears (that is if they're all plastic like the Supra Denso pumps) Definetly not something I would want in a daily driver.
    If they're not noisy, then I wouldn't hesitate at all. The one in my Eclipse has been in it for years and has never given me problems.
  9. Dec 19, 2010 at 7:54 AM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I have it. It's not noisy. Easy install. Fairly inexpensive.
    I would do it again.
  10. Dec 19, 2010 at 8:35 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Do you have to drop the tank for this ? Is there a kit to put a filter on the rail to protect the pump or do you just run it til it drops dead. ?
  11. Dec 19, 2010 at 5:54 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    You have to drop the tank. The URD kit comes with an external filter.
    Here is a pic of the filter.
  12. Dec 19, 2010 at 9:20 PM
    Gincoma
    Salt Lake City UT
    Is the gas going threw the external filter before it hits the pump...if not I dont understand why it would be nessaccary...unless its one of those "hell ya i gots an external filter dude" just to say you have one :rolleyes:
  13. Dec 19, 2010 at 10:37 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    Maybe I'm mistaken but isn't the point of the fuel filter to filter contaminants before they reach your engine and injectors?
  14. Dec 19, 2010 at 10:44 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    yes.
    gasoline fill stations have pumps on their nozzle lines, and the in-tank pumps in cars typically have a sock or screen to filter again. so that takes care of the fuel being clean before the pump. so, once the fuel is pumped, it gets filtered again by a fine media filter so it doesn't affect injection.
    that's weird because i had a 255 high pressure unit in my civic for almost 8 years...with no rear interior over the fuel pump cover, which is within reach from the driver's seat, and it was only a hair noisier than stock. it was noisy when priming and minimally noisy when running. nothing bad.
  15. Dec 19, 2010 at 10:53 PM
    george3
    new jersey
    tacoma
    Thanks. I had a filter on the rail on my 2000 Tacoma. When I changed it it was full of gunk. There is no filter on the rail on my 2008. So is this sock (which doesn't sound like much of a filter and can't be changed) supposed to do the job of the big filter that use to be on the rail. The one on the rail looked like the one in the pic in this post. Thanks.
    sock in the tank supposed to do the job of that n
  16. Dec 19, 2010 at 11:05 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    i'm just saying typically there is a pre-filter before the pump, usually a plastic screen "sock", and then another finer filter after the pump, as the use of an external filter was questioned when a pump is changed.
    regarding these trucks in particular, apparently the reason we don't have filters on the rail or in the engine bay of these trucks is because it is in the tank. i am not sure if the OE pumps have a pre-filter and a post filter, or the pre-filter handles all of the filtering, but regardless it is maintenance free and in the tank. when you change the pump, that might also change the filtering capabilities.
    i am guessing that someone would use an external filter like coupe showed above used w/ upgrade kits because the OE in-tank filtering ability is changed in some way or has been shown to be insufficient for certain high fuel demand/high power applications.
    check this out - http://www.urdusa.com/product_info.php?cPath=79_12&products_id=1260518592
  17. Dec 20, 2010 at 1:14 AM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    I believe with the OEM setup you have to replace the whole assembly to replace the filter. Thus the pump along with the filter costing 500+. The URD kit is cheaper and you don't have to replace the pump when the filter clogs up, or drop the tank to replace the filter.
  18. Dec 20, 2010 at 1:22 AM
    Gincoma
    Salt Lake City UT
    Ordered the URD upgrade kit....hope all goes well and solves my engine lack of power :) I'll post and let everyone know how it goes...heard instructions are top notch...
  19. Dec 23, 2010 at 1:12 PM
    mh3kgt
    mh3kgt -TACOMBO-
    Elko, NV
    07 TRD Sport
    OME 885's, OME Nitros front, Billy 5100's rear, 1.5"AAL, Satoshi'd Billet Grille, 18" Moto Metal 955's Plastidipped, more to come
    I'm helping with the URD pump install tonight. Should be done in an hour or so, I'm thinking lifting the bed would be easier than dropping the tank...we'll see. Probably gonna end up gettin one for my truck too if it makes that big of a difference. I'd like to have the added protection of an external filter before the rail, I'm approaching 30k miles on the truck, and have read that's when the stock pump starts to get clogged up anyhow.
  20. Dec 23, 2010 at 1:59 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Here are a few pics from an previous install. These might help you.
    Mark hoses & outer ring location.
    Removing hose clips.
    There is an outer ring that gets removed. Toyota makes a special wrench. I used a hammer & a screwdriver.
    APRX1158_15a2a32121eac35ae3a0cc31e41f599abd126260.jpgAPRX1161_51b695d84cd350b425c6bcb7d5d3d246de386704.jpg
    On this operation of cutting slits in the bowl, I have also used a hot xacto knife.
    ChillyBear likes this.
