walker evans
Discussion in 'Wheels & Tires' started by sydwayz04, Jan 24, 2012.
  1. Jan 24, 2012 at 5:28 PM
    sydwayz04
    sydwayz04 [OP] Well-Known Member
    Dustin
    belgrade
    11 acc. cab sr5 white
    stero system, couple subs, dwreck sliders, shackel flip, long travel air bags, h.i.d.'s, and some other cool stuff
    so i did a search and did not come up with anything on them, i am wanting a set of the street lock walkers, is there a reason why nobody is running them, i know ther are not cheap but is that the only reason, or will they not fir or something? is there anybody with them on here? thanks
  2. Jan 24, 2012 at 6:48 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Do you have link to the set you want, with the specs?
  3. Jan 24, 2012 at 7:00 PM
    sydwayz04
    Dustin
    belgrade
    no link i found some that say fj wheel but as of now walker's site is not letting me see anything, so no i am not loking at a specific one just them in general and was wanting to know why u dont here of any talk of them arond here, i will try to call them tomorroe and see if they can give me some info on what will work
  4. Jan 24, 2012 at 7:04 PM
    TexasTacoma37
    I can tell you what will work if you tell me what tire size you want to run, and on how much lift.
  5. Jan 24, 2012 at 7:10 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Aaron (blackhawk88) is running them, along with a few other members I can't think of right now.
  6. Jan 24, 2012 at 8:05 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    omf can set you up with walker evans. they clear the calipers in 16 inch and they meaning walker evans can custom make the wheel any way you like it off set and so on.
    i was very close to picking up a set this summer but, ultimately decided that the price was way to much. they are very nice wheels but, fuck for that kind of money i just couldn't do it.
  7. Jan 25, 2012 at 10:08 AM
    sydwayz04
    Dustin
    belgrade
    i am wanting to run a 265/75/16 with no lift, or as big as i can go with no lift, i will end up going with the king coilovers and some total caos uca but dont want it to be to much taller , probley go with shackel flip in the rear so like 1-1.5 lift in the front with the kings, always wanted a set of the walkers from day one and i know they are coin but worth it to me.
    can i clear 285's with no lift as i dont plan on doing the kings till summer and i need tires now, how much would i half to cut to clear them with no lift or is that even possable with out totaly cutting my truck up ?
    and if walker can make any ones i want what would be the ideal offset and suck then ?
  8. Jan 25, 2012 at 10:33 AM
    sydwayz04
    Dustin
    belgrade
  9. Jan 25, 2012 at 10:36 AM
    sydwayz04
    Dustin
    belgrade
    ok so just got off the phone with omf, great customer service, so ! walker does not come in a 16 only 17;s, not to big of a deal but was talking with the guy and he can basicly put a true bead loch on any rim for $250 or a street lock on any rim for $120 considering walkers are $390 i might go with a nother rim and just have them install a bead lock, like above i kinda like the factory toyota rim they did there phaze 6 ring on
    so back to basic if i wanted to run a 265/75/16 what would be the ideal off set for the rim, thanks
  10. Jan 25, 2012 at 10:42 AM
    TexasTacoma37
    zero offset on an 8" wide rim would give you the option of running a 265 now or a 285 when lifted.
    If it's a 9" wide rim you'll want -12 offset, and youll want to make sure that the 265 you select is approved for 9" wide rims.
  11. Jan 25, 2012 at 10:44 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    You can run a 265/75/16 on the stock wheels if you wanted, but if you plan to move up to a 285 then 4.5'' backspacing is recommended.
  12. Jan 25, 2012 at 1:34 PM
    sydwayz04
    Dustin
    belgrade
    ok cool thanks guys 4.5 backspacing it is then now i just half to find the rim i want, was thinking the leval 8 guardian with the spectra 6 omf bead lock rings??? to many choices :)
