Walking away from a 2001, 124k miles, $7.5k (odometer roll back)
Discussion in '1st Gen. Tacomas (1995-2004)' started by drosand, Sep 16, 2019.
  1. Sep 16, 2019 at 10:52 PM
    drosand
    drosand [OP] New Member
    So I found a 2001 Tacoma PreRunner V6 on craigslist listed for $7.5k. I figured it was a decent deal considering I can't find any crew cabs under 9k. I went to check out the car with my mechanic and let him do his thing (1.5 hour inspection including a test drive).
    He later and mentioned a few potential issues:
    • He believes that he heard a specific noise while driving, which paired with nearly black transmission fluid, could mean that the transmission is at the end of its life (noise could also be wheel bearing) Transmission repair: $2,600
    • Engine rear main seal area was leaking. Repair: $1,100
    • A little rust in the engine, loose hood, noisy window, corrosion on battery terminal...
    Things got really interesting when I pulled up the Carfax, which I probably should have done well before I hired my mechanic. In a span of two years (2009-2011) the 4th owner put on 100k miles. 5 emissions tests in 2 months (several failures) recorded the milage at over 250k. A year later (under a different owner), and emissions test recorded the odometer at 120k miles, triggering a roll back notice on the Carfax.
    A 100k+ roll back is a deal breaker for me. I'm not prepared to buy a tacoma with over 250k miles and at the very least I'm not sure how I'll be able to explain the roll back to the 7th owner when I decide to sell it.
    Thoughts?
  2. Sep 16, 2019 at 10:59 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Hard pass
    ylekot and CayucosTacoma like this.
  3. Sep 16, 2019 at 10:59 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Right choice is to walk away. You dont want to be the guy holding that bag.
    Could be that the odometer or cluster was replaced but the dude hasn't been upfront about it.
    Hamer95USA and jammer like this.
  4. Sep 16, 2019 at 11:03 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Walk away. There is another truck in better shape out there.
    jammer likes this.
  5. Sep 17, 2019 at 2:21 AM
    ylekot
    ylekot Active Member
    Where the roads are salt water November to May
    1995 Tacoma 2wd reg cab 5 speed w/ac but NO p/s
    stereo upgrade
    It would have to be WAY cheaper before I would even consider it.....HARD PASS
    Taco critter and robssol like this.
  6. Sep 17, 2019 at 2:24 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Walk, no, RUN away from that one!
    Welcome to TW!:hattip:
    GQ7227, jammer and Taco critter like this.
  7. Sep 17, 2019 at 2:30 AM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    I don’t even see this being a question.
  8. Sep 17, 2019 at 4:00 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    That sounds like a basketcase, run far away.
  9. Sep 17, 2019 at 7:17 AM
    jtakeda
    jtakeda Well-Known Member
    2002 Turd
    Run away.
    3-4 owners MAX. Ideally you want 1-2
    Once you get to 7 owners who knows what that thing has been through
    GQ7227 and opteron like this.
  10. Sep 17, 2019 at 9:30 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
