Wall Mounted Pressure Washing System
Discussion in 'Detailing' started by iampraneel, Feb 18, 2020.
  1. Feb 18, 2020 at 12:54 AM
    iampraneel
    iampraneel [OP] Well-Known Member
    2016 DCSB TRD Sport 2WD
    ***UPDATED SYSTEM IN POST 7***
    Hey guys check out the Wall Mounted Pressure Washer System I have in my garage. I’ve also listed everything you need with the exception of the PW to do a set up like this. It’s freaking awesome and makes washing the Tacoma so much more enjoyable.
    https://youtu.be/qHNkMzldmX8
    Deionizer Unit:
    Aquatic Life Spot-Free Car Rinse Unit - https://amzn.to/2Sv0UVY
    Aquatic Life Cartridges Mixed Bed Resin for Filtration (2 Pack) - https://amzn.to/2Y9agba
    Dixon 1/2" Valve - https://amzn.to/2StxxDy
    Hose Reel, Hoses and Fittings:
    General Pump D30002 3/8" x 100' Steel Hose Reel - https://amzn.to/2XT3Hyp
    UBERFLEX Kink Resistant Pressure Washer Hose 1/4" x 50' - https://amzn.to/2XUpk1m
    MTM Hydro 30.0026 Jumper Hose / Whip Line 3/8" x 2' - https://amzn.to/2SAQdS4
    3Ft Garden Hose - https://amzn.to/2YbNAY8
    M22 14mm X 3/8" Quick Disconnect - https://amzn.to/2O9vSEC
    Pressure Washer Gauge - https://amzn.to/2XX8Wgh
    2x Ultimate Washer High Pressure 22MM Adapter Fitting x 3/8-Inch Brass - https://amzn.to/2YhNi5L or 2x Mosmatic Nickel NPT 3/8" NPTM to Male M22 - https://amzn.to/2XXdaEP
    Ultimate Washer Female Coupler, 3/8-Inch, Stainless Steel, 2-Pack - https://amzn.to/2y33jxO
    Spray Gun:
    MTM Hydro SGS28 Gun with Built-In Stainless Steel Swive Spray Gun & Foam Cannon Kit (The one I have) - https://amzn.to/2JUsbxr
    Other Spray Gun and Foam Cannon options:
    MTM Hydro SGS28 Gun with Built-In Stainless Steel Swive - https://amzn.to/2St4VdL
    MTM Hydro SG28 Gun - https://amzn.to/2XUorpy
    MTM Hydro SG28 Gun and Foam Cannon Kit with Stainless and Brass Fittings - https://amzn.to/32CodC9
    MTM PF22 Professional Foam Lance and Cannon - https://amzn.to/2Y9DxCx
    TriNova Foam Cannon -https://amzn.to/2YgCsNG
    gorram, zr1001, WARPED5 and 2 others like this.
  2. Feb 18, 2020 at 2:02 PM
    gorram
    gorram Well-Known Member
    2016 Limited
    Good stuff, I did a similar project at the beginning of last year and I can't recommend it enough. I think I got that same inlet hose from Amazon. Any body reading, if you do a similar setup to this one of the most valuable components there is the swivel on the gun. That alone will improve the user experience of using a pressure washer ten fold especially if you've got a cheap PW hose.
    iampraneel[OP] likes this.
  3. Feb 19, 2020 at 2:17 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Nice setup....but am I the only one concerned about a pressure washer/water being that close to electrical outlet??
    gorram likes this.
  4. Feb 19, 2020 at 3:25 PM
    gorram
    2016 Limited
    Saw that and wondered if it was a GFCI. When I installed my setup I knew I had to upgrade the outlet to a 20 amp because when using a foam cannon you can easily tip the current over 15 amps. I'm pretty sure you can install a regular outlet fed off a GFCI which OP may have.
  5. Feb 19, 2020 at 6:05 PM
    iampraneel
    That outlet was not GFCI because it single outlet dedicated to the sprinkler timer, so I changed it out to a 15 amp GFCI. The one with the reset buttons.
    gorram - just a FYI because I don’t know your internal electrical wiring or your breaker set up but you mentioned you changed your 15 amp outlet to a 20 amp outlet. It’s not as simple as that to get 20 amps from the breaker to the outlet. 1. The breaker in the box has to be 20 amp. 2. The wiring has to be 12 gauge.
    gorram[QUOTED] likes this.
  6. Feb 19, 2020 at 6:39 PM
    gorram
    2016 Limited
    Correct that is what I did. To be more specific since I was tapping the water supply for the PW inlet where the water heater was I went ahead and tapped hot too and installed a hot/cold hose bib. The best spot in the small utility shed was directly over an existing outlet. No way was that going to work, luckily this outlet was on it's own breaker. Swapped it for a 20 amp, already had plenty of 12 awg on hand so i moved it to another wall where I could have two outlets since I was also installing a retractable power cord reel.
    Now when the hose bib does an inevitable drip it will be dropping right onto a metal box that has bare wire hanging out of it where I pulled the receptacle out. Dead of course but it looks nice and ominous.
  7. Jan 26, 2021 at 12:47 PM
    iampraneel
    I updated the system. Below is the new video with most of the components needed to build this.
    https://youtu.be/u5OpWoycmLg
    Deionizer Unit:
    Bucket Filler Hose - https://amzn.to/3pnh3MQ
    Ultimate Hose Nozzle - https://amzn.to/39WT7cE
    Shutoff Valve Shut-Off - https://amzn.to/2NxJEB7
    Solid Brass Garden Hose Elbow - https://amzn.to/2Ybkr1s
    Hose Elbow Connector - https://amzn.to/3iOyALK
    Pressure Washer, Hose Reel, Hoses and Fittings:
    Kranzle K1322TS Pressure Washer - https://www.obsessedgarage.com/products/kranzle-k1322ts-pressure-washer
    24" Long X 18" Deep Stainless Steel Wall Shelf - https://amzn.to/3sWSwk5
    3/8"NPT Female Thread M22-14mm Female - https://amzn.to/2Mq246t
    90 Degree Street Elbow, 3/8" NPT Female x 3/8" NPT Male - https://amzn.to/3pli5ZI
    Ultimate Washer 18717 Pressure Washers Stainless Male Nipple, 3/8-Inch, 2-Pack - https://amzn.to/3oerX6d
    Spray Gun:
    MTM Hydro SGS28 Gun with Built-In Stainless Steel Swivel Spray Gun & Foam Cannon Kit (The one I have) - https://amzn.to/2JUsbxr
    Veloci MTM Hydro PF22.2 Foam Cannon - New Bottle - https://amzn.to/388Kdpx
    TriNova Foam Cannon - https://amzn.to/2YgCsNG
    MGMDesertTaco and ace96 like this.
  8. Jan 28, 2021 at 12:53 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Looks like a great setup, I love the versatility. I know it varies based on the water in your area, but about how many washes do you get out of a pair of filters? I've been wanting to build one of these but I'm a little worried I'm just going to blow through media since our water is so hard.
  9. Jan 28, 2021 at 1:33 PM
    gorram
    2016 Limited
    I've got a similar setup minus the water deionizer. The more I looked into it the more I realized it's likely not worth it. It seems that most people that use them end up abandoning them for the cost of the resin refills. I can't recall the number but some are paying $5-10 per wash and that is only using it for the final rinse, which is all you likely need it for anyway. There's an English guy on youtube that has an RV channel that has a mod for a much larger resin canister that makes it more economical but nothing will help if the water going in is very hard.
    Bottom line is to try and stay out of the sun on extremely hot days if you can, putting up a carport may be a more worthy option in the longrun. Maybe look into "rinseless" washing products since by design they soften the water you're working with.
  10. Jan 28, 2021 at 1:58 PM
    clenkeit
    Colin
    Lakewood, CA
    Yeah, I've looked into various options and I like the idea of a bigger canister and buying the resin in bulk. Just requires more piecing things together. While I'm not looking to blow a bunch of $ on DI water it would be very beneficial to me. Carport is not an option and staying out of the sun is not always possible due to how our property is laid out. We also often wash 2-3 cars back to back and saving time on drying could be a huge help. Lastly, one big pet peeve I have is water spots in my engine bay after cleaning. It's really tough to dry an engine bay so having DI water for cleaning the engine bay would be a huge help as well - especially for the 4th car which basically has a "show car" engine bay.
    MGMDesertTaco likes this.
  11. Jan 28, 2021 at 2:39 PM
    gorram
    2016 Limited
    Engine bay should be even easier to manage than the exterior of a car in the sun, obviously you don't want to be cleaning it while it's hot. Have you ever used a rinseless product like ONR or Wolfgang Uber? When mixed with tap water it neutralizes the hard water enough that you can even get away with it drying on a surface if you get distracted and you can come back and wipe it right off. Even if you like to wash with a traditional foaming soap for the exterior of the car you can use a rinseless solution as a drying aid to spray on in between rinsing and drying with a towel.
  12. Jan 28, 2021 at 3:20 PM
    clenkeit
    Colin
    Lakewood, CA
    The sun drying the water out before I can dry it is not the issue. The issue is having to dry it vs not. Our water is very hard so EVERY drop of water that you don't get with the towel will leave water spots. It's nearly impossible to dry every drop in an engine bay since there are so many nooks and crannies. Even the exterior, we have to either use compressed air to get every bit of water out of every crack, body line, door jamb...etc or dry the car very, very well and then let it fully dry (the hidden nooks and crannies) before drying. If you leave any water in those nooks and crannies then drive the car the water comes out, streaks along the paint and then you have water spots.
    I have not tried those products specifically, but I have tried using various quick detailer type products as drying aids. They work well for the body panels but it still does nothing for the nooks and crannies that hold water from the rinse but which don't receive the drying aid product when sprayed.
    I don't mind drying the cars. I mind having to dry every freaking inch of them - anywhere body panels meet, anywhere there is trim/molding, the little gap between tire and lip of the wheel... Sorry, I'm working myself up over here!
  13. Feb 2, 2021 at 12:18 AM
    MGMDesertTaco
    https://dirinse.com/product/d-i-rinse-pro-100-system/
    This is the largest resin tank/ best bang for your buck depending on your water hardness of course. https://dirinse.com/product/d-i-rinse-pro-100-system/
    A lot of money up front, but it beats changing the resin in the smaller tanks every ten washes. I've got one, but I also have a whole house filter with separate sediment and charcoal filters and a separate salt/resin water softener https://aquasureusa.com/collections...h-iron-reducing-fine-mesh-resin-48-000-grains. I feel like Adam Sandler from the Waterboy when people ask my about my setup. :rofl:
    clenkeit[QUOTED] likes this.
  14. Feb 2, 2021 at 12:26 AM
    MGMDesertTaco
    I researched a lot about those Kranzles that Matt at Obsessed Garage has helped develop. Someday...Someday...
