Wandering and Darty Steering on 08 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silvermoose06, Mar 9, 2024.
  1. Mar 9, 2024 at 4:41 PM
    Silvermoose06
    Silvermoose06 [OP] Member
    Declan
    2008 Tacoma TRD Sport Black
    Bilistein 5100s Alpharex Pro Series Headlights Motometal 17" -10 Rims W/ Falken Wildpeak at3w Vivid Lumen FNG3 Fog Lights (SAE) Weather tech floormats LED Taillight/reverse bulbs
    Hey Guys! Having a little trouble tracking down an issue with unstable/wandering and at times even darty steering over 80 kmh and most noticeable around 100kmh (roughly 50mph, & most noticeable at 63mph) and had a pretty sketchy moment on the highway the other day. I lifted the truck about 2" and had it aligned. I have 2° of Caster, 1° of positive Camber and .5° of toe after alignment. LCAs and an outer tie rod were replaced and as far as I can tell my steering rack bushings are good and so are my wheel bearings. I also installed new Wildpeak AT3-Ws (265/70r17s about 32") a few months ago. The only other thing I could think of would be aftermarket UCA's to get proper camber and caster adjustments although my truck is technically "in spec". The truck has been meticulously maintained its whole life although today it now has 400k km (250k miles) help would be awesome thanks guys!
  2. Mar 9, 2024 at 4:51 PM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    Camber affects tire wear more than the handling, and the caster isn’t that low. The darting would have me looking at the rest of the ball joints and tie rods again, or the steering rack bushings. I guess wheel bearings could contribute, but if they were that bad, you’d probably have some vibration or humming you’d be trying to track down.
    Silvermoose06[OP] likes this.
  3. Mar 9, 2024 at 5:03 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I would think that with a 2" lift, you wouldn't have to resort to different UCAs. I'm at about +2" in the front and I didn't. I did have some trouble with tire wear (camber in at the bottom), and getting that straightened out helped the wandering.
    Find an alignment tech who will do more than just adjust the toe in, would be my recommendation. Your LCA bushings are likely seized so that may be an issue.
  4. Mar 9, 2024 at 5:05 PM
    Silvermoose06
    Declan
    Thanks! Whats the best way to test for steering rack bushings? I've had the truck apart and everything feels tight and is in good condition, just from a quick inspection now everything seems good and tight, though I don't have much time to get in there and look at everything.
  5. Mar 9, 2024 at 5:07 PM
    Silvermoose06
    Declan
    Camber in at the bottom is positive camber so that could be the wandering... as mentioned In my original post i put brand new LCAs with ball joints and bushings. And the alignment tech did adjust camber, caster and toe
  6. Mar 9, 2024 at 5:08 PM
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    Easiest would probably be a helper in the truck turning wheel back and forth with you under looking at the rack for movement.
  7. Mar 9, 2024 at 5:09 PM
    Silvermoose06
    Declan
    Ok, how much play is ok? my bushings hardly moved even when on rough pavement
  8. Mar 9, 2024 at 5:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    Darty in the auto-x world usually points to excessive toe out. Sometimes intentional when running a technical course.
    Caster should be set first, then camber (almost 0 on a truck) then toe
    Goal is equal numbers on each side
    TacoJoeBro likes this.
  9. Mar 9, 2024 at 5:17 PM
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    I personally would question/suspect any play in the rack bushings. They are rubber so the may be some deflection, but if the rack has movement when checking with a helper or prying on the rack with a pry bar, it’s probably worse with the weight of the truck driving down the road
  10. Mar 9, 2024 at 5:27 PM
    Silvermoose06
    Declan
    I found maybe an 1/8" of play in the bushings when steering the truck and 0 movement when using a prying bar...
  11. Mar 10, 2024 at 6:25 PM
    TacoTuesday1
    FL
    how do you know that the claimed measurements in original post are actually accurate
    I think 0 or around 0 toe is recommended, and 0 camber
    IDK about caster, and that may vary based on suspension components used
    but generally, even on both sides
  12. Mar 10, 2024 at 6:40 PM
    Silvermoose06
    Declan
    I guess I don't know aside from the alignment sheet given to me by whats supposed to be a trusted alignment shop local to me...
  13. Mar 11, 2024 at 3:51 AM
    Burritopa
    Burritopa Well-Known Member
    Sean
    NSB, FL
    '15 PreRunner 4 door 4 banger 5 bed
    I had the same issue in my 120k+ mile '15.
    3rd gen trd OR shocks/coils, replaced the uca w/ jba 4°, new oem lca and a new steering rack with outer ties. Fixed it right up.
    Tabs may be bent too, my driver side is and it'll loosen after a few months (currently waiting to get some DK's welded in at some point this yr)
    Alignment is huge too. More caster the better, helps track straight/center the wheel
  14. Mar 11, 2024 at 11:05 AM
    Silvermoose06
    Declan
    Thanks! Any thoughts on if it was the steering rack or the UCA'S that fixed it?
  15. Mar 11, 2024 at 11:11 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Might want to have a look at the alignment cams to see if they have slipped.
  16. Mar 11, 2024 at 12:18 PM
    Burritopa
    Sean
    NSB, FL
    I'd go w a good alignment and see if/how long it holds. These trucks are known to have crap racks esp if you beat on it
    Then have someone get in and turn the wheel to see if the rack moves where it shndt be.
    All old & loose parts certainly wont help tracking
