Wandering at highway speeds
Discussion in '1st Gen. Tacomas (1995-2004)' started by Black Hills Tony, Aug 30, 2011.
  1. Aug 30, 2011 at 6:20 AM
    Black Hills Tony
    Black Hills Tony [OP] Active Member
    Joseph, Or
    03 TRD 4WD
    I replaced my tires about a month ago, and now I've noticed increased wandering when driving on paved roads at highway speeds. It is particularly noticeable when the road has "ruts" worn into it. It's more of an annoyance than a performance or safety issue.
    The change in tires is not the only variable here. The old set of tires were my bridgestone blizzak winter tires mounted on cragar wheels with about .25" less backspace than the stock rims I put the new tires on. The blizzaks were p245/75/16s.
    The new tires are toyo open country a/t LT265/75/16 mounted on the stock wheels.
    I checked the threads concerning steering play. I have some very slight play in the steering slip joint, and some movement in the steering rack when I turn the steering wheel. Neither seem as bad as other people have described (no popping or clunking).
    Any thoughts?
  2. Aug 30, 2011 at 6:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Very well could be the tires themselves. I noticed more 'wandering' when I swapped out from the 245 series dunlops to a wider 265 series Cooper tire. Did you get the truck aligned when you had the tires replaced?
  3. Aug 30, 2011 at 6:27 AM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    x2 they should have aligned it when you got your tires replaced
  4. Aug 30, 2011 at 6:34 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    More caster..............x3 on the alignment with new tires on. Also went with wider tire.
  5. Aug 30, 2011 at 7:03 AM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    I had the same problem when I switched tires. Its believe its because they have a flatter, wider contact patch on the road. I found that if i'd air them up a little more than required( I run 44 psi) on my 285s, that its a little less squishy.
  6. Aug 30, 2011 at 7:19 AM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    I noticed the same problem when I changed the tires on my car. I verified the air pressure was correct and it was. After a while I just got used to the way it drives and I dont even notice it anymore.
  7. Aug 30, 2011 at 7:27 AM
    Demon Taco
    Demon Taco Well-Known Member
    Robert
    New Hampshire
    Gold Tacoma SR5 4X4
    maybe the side wall of the tire is more flexible than your original tire set up.different rated tires have different side wall constuction.what about rim width?are they the same.
  8. Aug 30, 2011 at 9:19 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    fresh tires don't scrub as easily...
    it's likely yer toe setting is off some
    get an alignment done...
    If it still wanders...
    then it could be deteriorated(loose) rack mnt bushings or ITRE play
  9. Aug 30, 2011 at 9:22 AM
    bicklebok
    Ronnie
    Montgomery, AL
    Plus one
  10. Aug 30, 2011 at 6:55 PM
    Black Hills Tony
    Joseph, Or
    03 TRD 4WD
    hmmm...last alignment was in july 2009 after I put bilstein 5100s on. I put the front coil over setting on the middle setting (.75" lift over stock?) which made the handling kind of tweeky untill I got an alignment done.
    I think I'm probably due for another alignment. If that fixes the wandering, cool. If not, at least it should help my tires last longer. Like some posted, I might just get used to it.
    Thanks everyone!
  11. Aug 30, 2011 at 9:03 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Pressure?
    I had Toyo ATs and they worked great... I don't recall what I ran them, but they probably work best about 5 psi or a tad more under their max. listed pressure, but likel;y more than the door jam pressure which was for the soft Rugged Fails or whatever yours came with, new?
  12. Aug 30, 2011 at 9:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Billies for the 1st gens don't have a .75 setting. If you used the middle setting, its 1.25".
    If you are running the stock coils, that lift should allow a decent caster alignment. If you are running aftermarket coils (eibachs or OMEs) then that may be some of the issue you are having.
    More that 2.5" over stock will reduce or eliminate altogether, the ability to get a reasonable caster setting. Wandering at highway speeds is an indicator of a low caster setting.
  13. Apr 15, 2012 at 7:52 AM
    Black Hills Tony
    Joseph, Or
    03 TRD 4WD
    Ok,
    so I just swapped out my winter tires (245/75/16 michelin LTX winter 10PR) for the Toyo ATs again. I had no wander issues with the michelins (they are 245s on different rims, so it's not exactly apples to apples).
    I've been experimenting with different tire pressures.
    When I run the toyos at the door-jam recommended pressures (26 front, 29 rear), they handle fine on the highway. I jacked them up to 57 front and rear, and found that it wandered like crazy. I had originally intended to jack them up to just shy of the max tire pressure of 80, but my tire pressure gauge only goes up to 60. It's probably good that I didn't test 80 psi considering the wandering 57 psi caused while passing on a two lane highway at 85 mph (a bit sketchy and a lot stupid, but it was in the name of science!).
    Next I'm gonna take the fronts back down to the recommended 26 psi, and keep the rears up at around 45. After all, the primary reason I wanted to use higher pressures is for hauling firewood.
  14. Apr 15, 2012 at 8:01 AM
    Black Hills Tony
    Joseph, Or
    03 TRD 4WD
    Nope, I'm running stock trd springs. I had an alignment done a few weeks after putting the billies on back in 2009. It was a big improvement at the time, and I didn't have any issues with highway handling for the past three years until I switched to the toyos.
  15. Apr 15, 2012 at 8:54 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    It probably wouldn't hurt to have an alignment done if you've been switching out tires and your last alignment was in 2009.
    I had a 2002 4Runner that really pulled, had it aligned but then found out it ended up being a screwed up axle and axle housing, something the used car dealer failed to acknowledge, either on purpose or just from not knowing. But the main sign from that was really awful/weird tire wear from the tires basically riding half sideways down the highway. Also the ride was very bouncy/rumbly more than normal.
    So it could be a number of factors, but at least a tire alignment will give you a piece of mind?
  16. Apr 16, 2012 at 7:08 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I have noticed on my 2 2nd gens from regular alignments since I buy 3 yr alignments, that the toe is notorious for not staying put and a coupla times the camber had to be adjusted too. This wasn't from any kind of extreme driving, lift or tire setup either.
  17. Apr 16, 2012 at 8:45 AM
    natemoore2088
    natemoore2088 Well-Known Member
    Nate
    Idaho
    '97 Tacoma 2.7
    2" lift Pre-runner bumper Deck Plate Doug Thorley header Cherry Bomb
    After your alignment, be aware that wider tires will always wander more than skinnier tires. They have more surface contact with the road and tend to follow ruts more aggressively.
  18. Apr 26, 2012 at 4:57 AM
    Black Hills Tony
    Joseph, Or
    03 TRD 4WD
    thanks folks,
    I'll post again after I get an alignment
  19. May 16, 2012 at 6:37 AM
    Black Hills Tony
    Joseph, Or
    03 TRD 4WD
    finally got an alignment. They said the right wheel way out of proper toe (it needed more toe-in). That was them main problem. They also had to make small adjustments to the camber. Bottom line: no more wandering at highway speeds. Thanks for the tips everyone!
  20. Jul 7, 2012 at 8:11 AM
    mmiller2002
    mmiller2002 Member
    Fort Worth, TX
    2004 Double Cab 2wd
    Old thread, I know.
    I have an 04 double cab 2WD that wanders. What are good rules of thumb for a street handling alignment? I know what's good on my Subaru WRX for the track, but know nothing about trucks. i.e. zero toe all around, -X degrees negative camber up front, etc.
    Everything seems tight underneath, and I have new tires. Is the Taco known for this?
    Thanks!
