Wandering/drift issues on the hwy
Discussion in 'Suspension' started by cyantucaz, Dec 1, 2009.
  1. Dec 1, 2009 at 4:59 PM
    cyantucaz
    cyantucaz [OP] Member
    Vail, AZ
    07 4x4 Quad Cab
    5100'S ALL AROUND WITH 885 COILS AND LIGHT RACING UCA UP FRONT. 1.5 AAL IN THE BACK. SPIDERTRAX SPACERS. IPOD ADAPTOR. SEXY WIFE IN THE PASSENGER SEAT!!
    Hey guys I got an issue that just developed after i rotated my tires last week. Ever since then my truck wanders or drifts all over the highway. The set up I have is LR UCA's and OME 885 coils up front with 5100's all around, an AAL in the back and Goodyear MTRs. I did look at my tires and they are wearing evenly. Do you guys think just another alignment is order or is there something else that could be wrong?
    Any thoughts would be appreciated.
  2. Dec 1, 2009 at 6:48 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    sounds like alignment, had the same issues.
  3. Dec 2, 2009 at 1:30 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Definitely sounds like an alignment issue
  4. Dec 3, 2009 at 4:43 PM
    david7268
    david7268 Well-Known Member
    Tucson, AZ
    2012 DCLB 4x4 TRDSport
    NONE.....yet!
    Check the lugnuts.....
  5. Dec 3, 2009 at 5:36 PM
    mcgiiver
    mcgiiver Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    Did you rotate only front to back? If you swapped sides it can cause this which you describe. If so, it will get better as the tires wear in to the new rotation, but it will take a while.
  6. Dec 4, 2009 at 5:11 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    ^^ x2 for sure.
  7. Dec 4, 2009 at 10:11 PM
    Negative1
    Negative1 Well-Known Member
    Check your tire pressure... Sounds stupid, but will throw your rig all over the road if there is a significant loss of pressure in one or more tires. And its an easy fix.
