Wandering taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joey//BLKTRDsport, Feb 10, 2017.
  1. Feb 10, 2017 at 8:54 AM
    Joey//BLKTRDsport
    Joey//BLKTRDsport [OP] New Member
    2008 blk trd sport
    Leveling kit bilstien shocks k&n air intake
    I was interested in opinions on what would cause truck to wander all over the road. It literally just about pulls the stirring wheel out of your hands when going down a bumpy road with dips in it. Any suggestions?
  2. Feb 10, 2017 at 8:58 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Alignment ?
  3. Feb 10, 2017 at 9:04 AM
    Governor
    Governor Well-Known Member
    Las Cruces, NM
    2016 DCSB TRD OR 4x4
    I'm wondering if you mean "wandering"? :tumbleweed:
    scottalot likes this.
  4. Feb 10, 2017 at 9:27 AM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    ^^^ This....
    OP, you really need to lift the front of the truck off the ground and check all the normal front end suspension and mounting. Plenty of youtube videos covering this. Looking for wheel play (left/right wiggle, 12 oclock and 6 oclock wiggle, take a pry bar and see what front end bushings move too much, etc).
    If it's bad enough to jerk the wheel out of your hand, then the problem (shot ball joint or something) should be fairly visually obvious.
