wanna run 35s, what do I gotta do???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TicoTRD, Mar 12, 2014.
  1. Mar 12, 2014 at 8:36 AM
    TicoTRD
    TicoTRD [OP] Well-Known Member
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    so yea the title says it all. I have a 3" lift now with 33s but I really wanna go bigger. so ive heard tht u need to trim your fenders, ive heard u need to get different gears. I just a list of what I would need. atleast that would be easiest. thanks in advance.
  2. Mar 12, 2014 at 8:38 AM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
  3. Mar 12, 2014 at 8:39 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
  4. Mar 12, 2014 at 8:39 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    :facepalm:
    Search much?
    Use the link they gave you and check out all the guys build threads
  5. Mar 12, 2014 at 10:13 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    I did search and nothing specific. and I looked at all the guys build threads with 35s and they all have different mods.
  6. Mar 12, 2014 at 10:19 AM
    RelentlessFab
    Eric
    Sparks, NV
    each to their own basically. It's up to you to decide which methods shown you prefer for fitting them on to your own truck. That's why I say look at all the builds. It will give you an idea exactly what/where the main issues are that everyone has and then you can address those and the rest is up to you.
  7. Mar 12, 2014 at 10:21 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    gotcha gotcha. so I see some people do LT with the 35s....but I thought it was a necessity to run glass with LT???
  8. Mar 12, 2014 at 10:24 AM
    RelentlessFab
    Eric
    Sparks, NV
    Glass is a necessity with the 3.5" over kits. On the 2" over kits, you're usually still narrow enough to run stock fenders as long as your state isnt too picky about fender covering and you dont get too crazy on wheel backspace/tire selection.
    With a +2" LT kit, a lot of the rubbing issues dissappear as well, some guys even go to 37's with the +2" LT kits. For example, you have to clearance the body mount/pinch weld/other crap in the back of the fender wells for 35's on a standard 3" lift. The AP +2" lt kit moves the front tires forward an inch, and the radius of a 37 is an inch larger than a 35 so with similar clearaning to fit a 35 without the LT kit, you can fit 37's with the LT kit.
  9. Mar 12, 2014 at 10:38 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    ok I see what your saying. so looking at some of the builds...all I would really have to do to run 35s now is to do a lot of trimming, and probably trim my fenders?
  10. Mar 12, 2014 at 11:15 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I wouldn't call cutting 2 inches out of each fender "trimming" in order to fit 35's you will need to make irreversible changes to your truck.
  11. Mar 12, 2014 at 11:41 AM
    TicoTRD
    Tico
    Summerville, SC
    '11 MGM SR5 AC
    True. And I got ya.
