wanna take my front diff drop off
Discussion in '1st Gen. Tacomas (1995-2004)' started by brianchase, Oct 5, 2009.
  1. Oct 5, 2009 at 6:29 PM
    brianchase
    brianchase [OP] bchase
    east texas
    04 tacoma sr5 v6
    3" inch suspension lift, leveling kit, 33" bone crushers
    i wanna take my front diff drop off. what do i need to get and do?
  2. Oct 5, 2009 at 6:31 PM
    BigBawlzTaco
    BigBawlzTaco Wanna know how I got these scars?
    Forsyth,Georgia
    Chevy Avalanche
    Straight piped.
    This looks like a case for Chris4x4
  3. Oct 5, 2009 at 7:04 PM
    brianchase
    east texas
    04 tacoma sr5 v6
  4. Oct 5, 2009 at 7:06 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    thats the cue when chris appears from nowhere and has this knowledge that fixes everybodys problems
    he is like steven hawkins for tacomas not black holes
  5. Oct 5, 2009 at 7:12 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    thats good...why do you want your diff drop off? its there for a reason
  6. Oct 5, 2009 at 7:16 PM
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    x2, i assume there is a good reason?
  7. Oct 5, 2009 at 7:39 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    just do the install but reverse it?? Why you want it off anyways??
  8. Oct 5, 2009 at 7:45 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    All you need is the stock length bolts. Remove the spacers, and install the OEM length bolts. It should only take about 30 minutes, max.
  9. Oct 5, 2009 at 7:48 PM
    brianchase
    east texas
    04 tacoma sr5 v6
    i want if off because it acts like a bulldozer blade in a hole. i have to get a pic of it posted 2mor it looks dropped a few inches 2 me. it has blocks in rear and lift and leveling kit up front. sittin on 305 65 17 dick cepek crushers. its my first yota and i'm in love. my cv axels are almost straight, thats how low my diff is dropped
  10. Oct 6, 2009 at 5:42 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    thats a good thing to have you cv axels straight, but if you want it off go ahead.
  11. Oct 6, 2009 at 2:45 PM
    Carone
    Carone Well-Known Member
    NOR CAL
    LOOK HERE!!! 02 TRD xtra cab v6 4x4 white
    Look at my Build
    Get a small diff drop 3/4" orstack a few washers or go no drop seem to be no real diffrence. It you want to know if they work or not check out TTORA and you'll find more of an argument then its worth.
  12. Oct 6, 2009 at 4:15 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    i just installed mine today I think they are worth having in, many say "they won't make a difference" but I think overtime miles and offroad abuse they will.
  13. Oct 6, 2009 at 6:13 PM
    brianchase
    east texas
    04 tacoma sr5 v6
    i understand the benefits of diff drop, but i ultimatly want more ground clearance. look at the one with diff drop and tell me what i really have. thanx
  14. Oct 6, 2009 at 6:22 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    wow lot of lift Im not too sure on that set up but it looks like you need em to me (they are like 5 or 6" long. Im sure someone will chime in with a better answer but from what I see I dont see a way to run that set up with out them??
  15. Oct 6, 2009 at 6:33 PM
    BigBawlzTaco
    Forsyth,Georgia
    Chevy Avalanche
    Straight piped.
    eh hem.....
    THIS LOOKS LIKE A CASE FOR CHRIS4x4!!!!!
    :cookiemonster:
  16. Oct 6, 2009 at 7:56 PM
    brianchase
    east texas
    04 tacoma sr5 v6
    how do i get more ground clearsnce since i have a big diff drop?
  17. Oct 6, 2009 at 8:20 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    Looks like you have something like a 6" procomp lift or similar?? thats just how they are you only get more ground clearance by running a larger tire im pretty sure you are stuck with it the way it is.
  18. Oct 6, 2009 at 9:04 PM
    brianchase
    east texas
    04 tacoma sr5 v6
    hers what i got
  19. Oct 8, 2009 at 8:43 PM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    A diff drop kit that most of us think of consists of 2 extended bolts, and 2 spacers. They drop your diff about an inch. Some people praise them, others don't see the point.
    With that said, what you have there is a drop bracket lift kit. Companies like Fabtec, Pro Comp, and Tuff Country make these kits for our trucks and they range usually between 4''-6'' of lift. Because of the high lift, a drop bracket needs to be installed (not spacers) in order to not put strain of the cv shafts. A big part in accomplishing this is by cutting out your stock cross-member and replacing it (welding it in place) with one supplied in the kit. The result is a diff clearance not that much greater than what you had to begin with. This is one of the major cons of drop bracket kits.
    What this means is that a lot of work went into putting that lift on the truck and it's gonna take a lot of work to take it off. That new cross-member is gonna have to be cut out, and replaced with a stock cross-member. Stock cross-members are not easy to come by. You may need a welder to weld it back in if you are not handy with a welder. Your steering knuckles have most likely been replaced with aftermarket ones. Hardware is gonna have to be changed. You basically have to dismantle the front end and return it to its stock form, Then decide what route your gonna go to lift the front end, which is a whole other story.
    OR you could lift that baby higher and put some bigger tires on, this would raise your diff's :D.
  20. Oct 8, 2009 at 8:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Wow...Sorry I missed this. Like mentioned. You have a drop bracket lift. The only way to lower it, obviously, is to remove it. You can unbolt everything, and return it to stock. You can get a new crossmember to replace the one that was cut out, from Toyota. They are pricey. Last time I check, a new cross member was close to (or more than) $300.00. Then, its gonna need to be welded in place, or bolted on some trucks. Keep in mind, you are then going to be at stock height.
