Wanna trick for drivers door noises
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jake1530, Dec 9, 2016.
  1. Dec 9, 2016 at 3:41 AM
    Jake1530
    Jake1530 [OP] Well-Known Member
    2015 Tacoma TRD
    First pardon for any grammar errors doing this on my phone. Ok I have a 2015 DCSB that I bought new last May. I've never had wind noise but I HAD ( up until this morning) a rubbing noise, if that's the best term to use. Light shunned on marble head as I was driving home last night. I remember a trick I was taught in my previous truck a 2005 GMC Sierra. Get a spray can of silicon, spray it on a clean Terri cloth rag and while the door gaskets. The gaskets stop making the noise. Hope this helps someone
    buzzkill911, DrFunker and ChadsPride like this.
  2. Dec 9, 2016 at 3:46 AM
    DrFunker
    DrFunker Well-Known Member
    :thumbsup: Thanks.
    ChadsPride likes this.
  3. Dec 9, 2016 at 4:23 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Yep, door seals need a little maintenance also. Aerospace 303 protectant works good.
    R0dzilla75 likes this.
  4. Dec 9, 2016 at 8:45 AM
    Wasatch
    Wasatch Well-Known Member
    Same problem here. I use Armor All wipes or spray. Works really well.
  5. Dec 9, 2016 at 10:22 AM
    wolmar72
    wolmar72 Well-Known Member
    Jon
    Newport Beach CA
    12 dual cab 4x4
    WD 40?
  6. Dec 9, 2016 at 11:43 AM
    spitdog
    This is a quote from there product page, so they say yes. But I always was under the impression not to use petroleum based products on rubber.
    WD-40® Multi-Use Product can be used on just about everything. It is safe to use on metal, rubber, wood and plastic. It can also be applied to painted metal surfaces without harming the paint. Polycarbonate and clear polystyrene plastic are among the few surfaces on which to avoid using a petroleum-based product like WD-40® Multi-Use Product.
  7. Dec 9, 2016 at 11:50 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    At the dealership I work at we use 3M dry type silicone. The weather strips absorb the silicone which causes them to swell slightly.
    Jake1530[OP] likes this.
  8. Dec 9, 2016 at 12:25 PM
    kukimonsta
    kukimonsta Well-Known Member
    G
    Alameda, CA
    2012 SSM DCSB TRD OR
  9. Dec 10, 2016 at 11:24 AM
    Jake1530
    2015 Tacoma TRD
    NAAC, now you got me thinking, maybe a little swelling would be good?
    NAAC3TACO likes this.
  10. Dec 10, 2016 at 1:55 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    WD40 contains petroleum distillates. This means it tends to react negatively with rubber and rubber-like compounds. Remember the rule of cleaning - "like dissolves like".
    What makes silicone unique is that it is rather inert.. it doesn't react with much, and when used as a lubricant it doesn't leave behind a visible element or any odor.
  11. Dec 10, 2016 at 5:41 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Use pure silicone.Water proof and almost permanent.And does not clean up well on clothes.Try waxing the door jam first.
