Want 2" lift. Do I use shocks/AAL or spacers/blocks?
Discussion in 'Suspension' started by TacomaMatt, Jun 2, 2012.
  1. Jun 2, 2012 at 11:25 AM
    TacomaMatt
    TacomaMatt [OP] Well-Known Member
    09 4x4 TRD OR AC 4.0L
    5100s x4; Front @ 2.5 & 1.5" AAL, Truxedo Lo Pro, WeatherTech window deflectors & floor mats
    Hey guys,
    I've been reading a lot of your posts and learned a lot. However, I am torn between 2 types of lifts. Please let me know what you recommend.
    I have a 2009 TRD Offroad with 2+1 leaf spring. I have some sagging and want to lift it about 2 inches (give or take). I don't want a huge amount of lift, just something that gives my truck a "beefer stock look." I do want to put bigger tires on too, but not sure how big. I won't take it offroading. I did read how certain types of lifts can cause other problems down the road like, alignment problems, broken shocks, ball joint problems, etc. I do not want to lift it and then deal with problems in the future.
    The two options I'm interested in are:
    1. Spacer lift for the front and a block in the back.
    2. Height adjustable Bilstein 5100s up front (1.75" or 2.5) and a 2" AAL in the rear.
    What option do you recommend and why? Or is there a better way to lift it?
    If I have to pay more for a lift today to avoid more expensive repairs in the future I'll do it. Thank you for your time!
  2. Jun 2, 2012 at 11:28 AM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    2, no questions
    Spacers/blocks can be bad for your truck. They cause axle wrap and are more for the aesthetic side of lifts. 5100's/AAL provide more travel and none of the problems of spacers/blocks
  3. Jun 2, 2012 at 11:29 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    From personal experience I can advise to stay away from blocks
  4. Jun 2, 2012 at 11:32 AM
    Day Cowboy
    Day Cowboy Well-Known Member
    Day Cowboy
    MS
    2011 Tacoma TX TRD 4x4
    AFE Pro Dry Air Filter, Toytec Ultimate 3' Lift, LR UCAs, WeatherTech Floorliners, Wet Okole Seat Covers
    The Bilsteins will be your best bet. Even if you do zero offroading.
  5. Jun 2, 2012 at 11:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Option 2 is a far better choice.
  6. Jun 2, 2012 at 11:47 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    I would recommend #2 by a long margin, just like everybody else. There are always better ways depending on your budget. For example the add-a-leaf can consist of 1 or 3 leaves, etc.
  7. Jun 2, 2012 at 11:55 AM
    TacomaMatt
    I've read that the AAL will make the ride lousy. Some suggest billies in the rear to compensate. I also read the 5100s with the stock coils cause the caster to be out of spec. Have you run into this? UCAs will be required if I can't get the alignment right. What are the drawbacks to the spacers/blocks?
  8. Jun 2, 2012 at 12:37 PM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    My AAL was a tad stiff (being the 2" one) but it has broken in nicely. 5100's should be fine when it comes to alignment. I'm running mine at .85" with eibachs and my alignment is in spec. UCA's aren't needed but they are a great idea. Drawbacks for spacers/blocks are harsh ride, even more so than the AAL. Spacers are also a cause for less travel offroad
  9. Jun 2, 2012 at 12:43 PM
    Pugga
    Massachusetts
    Icon and Wheeler's both make a 3-leaf AAL that rides very nice. If you lift the front up over 2.5", you could end up having alignment issues but you should be fine with stock UCA's. For what it's worth, you'd end up with the same potential alignment issues with spacers also.
    The drawback to spacers up front is they ride like crap and you run the risk of breaking your shocks. By using a top plate spacer, it spacers the shock down meaning you can bottom out the shock before you hit the bump stops, forcing the shock to absorb the shock of bottoming out. This can lead to breakage and put your truck out of commission.
    Blocks promote axle wrap which can wear out a leaf pack prematurely.
  10. Jun 3, 2012 at 12:34 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    bilsteins and a 2" aal, done
  11. Jun 3, 2012 at 5:49 PM
    DevL
    DevL Well-Known Member
    Well... if you are under warranty get TSB rear leaves. If you get 33" tires you will need axle relocatiin plate do to forward axle motion under negative arch. This acts as a 3/8" lift on its own and is unavoidably necessary if you dont get longer rear bumps.
  12. Jun 9, 2012 at 12:29 PM
    TacomaMatt
    Thanks for the info. I decided to go with billies and an AAL. I want a slight rake and stock UCAs.
    1. Do I set the billies at 1.5" or 2.5"?
    2. I don't have the TSB. Do I get the 1.5" or 2" AAL?
    What do you recommend?
  13. Jun 10, 2012 at 11:26 AM
    Raz4back
    Raz4back Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
    I'm about to do the same. I plan to set the Billies at 1.75 and do the 1.5 add a leaf. That should leave the rake at slightly less than stock.
  14. Jun 11, 2012 at 4:26 PM
    TacomaMatt
    I just got off the phone with the guys at Down South Motorsports and Toytec Lifts. They both recommended the same thing. Looks like it's time to spend some money...
    Are you going to get Billies for the rear?
  15. Jun 11, 2012 at 4:30 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
    what did they recommend?
  16. Jun 11, 2012 at 4:32 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    #2 is the one a only correct answer to this equation sir :cool:
  17. Jun 11, 2012 at 5:45 PM
    TacomaMatt
    To guarantee alignment in specs: 1.75" in the front and 1.5 AAL for a slight rake (no TSB).
  18. Jun 11, 2012 at 6:53 PM
    Raz4back
    Brett
    Benton, Arkansas
    Yeah, I'm going front and rear. The Billies are supposed to be here on Wednesday so I'm going to do the install this weekend. I'm still trying to decide whether to go with The wheelers single AAl or the three leaf AAL.
  19. Jun 12, 2012 at 3:24 PM
    TacomaMatt
    Let me know what you decide to go with. I'd like to see pictures too. I plan to make my purchase in a day or two. I was set on the Toytec AAL but now I'm checking out wheelers. So many options...:confused:
  20. Jul 30, 2012 at 9:17 PM
    Rickshaw
    Rickshaw Well-Known Member
    Maryland
    Brush Gaurd, side rails, front bilstein's at 1.75, wheelers 1.5 aal, udercover toneau cap
    Looks good Raz, im going with the same setup. Also getting the Mickey Thompson 265/70/17's. Should be put on Friday. Which did you get the single or 3 leaf aal?
