want a nice ride for potholes - i also need a terminology lesson
Discussion in 'Suspension' started by packfan88, May 19, 2011.
  1. May 19, 2011 at 3:20 PM
    packfan88
    packfan88 [OP] Very Nice !
    Acworth, GA
    Billy Lift, Cooper STT Pro, Westin Step bars, tinted, rain gaurds, EBC rotors hawk pads
    Im trying to figure out the proper term and set up for city driving. NYC is loaded with potholes and it will destroy a vehicle if you arent careful. Im looking to get my truck set up for the best pothole defense around. I want to be able to ride over pot holes with out having to worry.
    Im not sure if im looking for a soft ride, and reactive suspension or whatever else it may be called. Ever see a Baja500 truck flying thru the desert and the suspension is just floating the truck over the terrain? I want that in a cty version lol.
    Can someone tell me what it is that allows for that sort of suspension? Basically i want to go over bumps around 2" tall with out feeling them very much. Am i looking for a luxurious ride? I havent been in enough luxury cars to know if they handle potholes well. is it a stiff suspension to keep those wheels stuck to the pavement and the springs bouncing?
    Anyway, I hope i explained this enough but if not, i can get more descriptive.
    If anyone knows what i need to buy to accopmlish this feat let me know. If anyone has any input on what sort of actual hardware is needed for this that woudl be appreciated.
    thanks
    mike
  2. May 19, 2011 at 3:23 PM
    norcal4banger
    norcal4banger 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    Long Travel!!!!!!!!!!!
  3. May 19, 2011 at 10:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The desert racers do it by tuning the compression and rebound settings on their shocks. Also, in their case, maintaining lots of speed helps too.
    Talk with Marco at Downsouth Motorsports. Those guys know their stuff when it comes to how to make suspensions work.
  4. May 20, 2011 at 7:58 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
  5. May 21, 2011 at 9:17 AM
    Mescalero
    Mescalero Beretta Taco
    Anderson, SC
    '15 DCSB TRD PRO Mag Gray
    See if they make one of these for the tacos...
    Gotta be atleast one out there...
  6. May 21, 2011 at 9:27 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    What kind of speeds do you usually hit these pot holes at? Im guessing a pair of king coilovers would do you well
  7. May 21, 2011 at 9:33 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    this is always custom made so technically yes they make it for our truck
  8. May 21, 2011 at 9:48 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    bigger rims and tires will go over potholes easier rather than into them
  9. May 21, 2011 at 9:57 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    Small rims, Taller tires, and softer springs. It'll float but you can kiss spirited driving goodbye.
  10. May 22, 2011 at 6:55 AM
    packfan88
    Acworth, GA
    I guess you have never driven in NYC :)
  11. May 22, 2011 at 6:57 AM
    packfan88
    Acworth, GA
    Driving in NYC in a life and death battle with crazy cab drivers for lanes space is almost like a Baja race. I going to say Id like to cruise over them at around 30 mph with out having the truck skip around like a lightweight fighter on a pogo stick.
  12. May 22, 2011 at 6:59 AM
    packfan88
    Acworth, GA
    What exactly is spirited driving? Are you talking about going fast on nicely banked turns? If so, its not to be found in NYC anway. I rarely get over 50mph unless im on the parkway to the jersey shore (jk)
  13. May 22, 2011 at 7:00 AM
    packfan88
    Acworth, GA
    So long travel is the term for the "type" of suspension I am looking for? So If I come in TW looking fo radvice ona long travel suspension set up, people will know what Im talking about and what parts I would need to complete the setup?
    Sorry if i sound clueless, but i am ...and im ashamed.
  14. May 22, 2011 at 7:25 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    avoid them.....
    bad on all your shit no matter what.
  15. May 22, 2011 at 8:17 AM
    packfan88
    Acworth, GA
    I guess you read the first post and thats it?
    again, its not possible. Maybe where you live it is possible but not here. Some streets in NYC are not only covered in potholes and the raised asphault cause by pothole repair, but have no choice but to drive over them. Some street have more square inches of potholes and pothoel repair than they have of NO potholes or past pothole repair.
    Sure i can slow down to make it easier on my suspension, but then i wouldnt make the light. If i dont make that light i miss the next 10 lights and it will take 10 mintues longer to get where Im going.
    NYC is a fast paced place. Sort of why the saying goes "if youre not from here, you wont survive here". Some people are better suited for a slower place like the South or the suburbs. Driving slower and taking the path less traveled isnt going to happen.
    I am going to hit them and Im going to hit them at a higher rate of speed than most would.
  16. May 22, 2011 at 8:18 AM
    pudge151
    Sean
    Connecticut
    get a 3 inch lift, maybe coilovers up front if you wanna spend some $$$$$
    then get some big ass tires. you wont be able to do much more, its a truck, its not going to ride smooth, especially thru pot holes
  17. May 22, 2011 at 8:23 AM
    packfan88
    Acworth, GA
  18. May 22, 2011 at 8:23 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Stock would be best.
  19. May 22, 2011 at 8:27 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I've driven most of NYC and your potholes aren't aren't worse then most major cities. If you are worried about your ride comfort you should be worried about the integrity of your tires as well. A pothole will dent a rim in no time flat.
    I would think that leaving 10 mins early would make more sense than trying to upgrade enuf to hit potholes at speed. You WILL break SOMETHING even with upgrades....
  20. May 22, 2011 at 8:28 AM
    packfan88
    Acworth, GA
    dude....you really think a 4 word answer to a page long discussion is going to help the topic at hand?
    Or are you just trying to get a +1 to our post count?
