Want less body roll but don't want ride height change
Discussion in 'Suspension' started by sriley727, May 3, 2009.
  1. May 3, 2009 at 1:10 PM
    sriley727
    sriley727 [OP] Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    I've noticed that my fathers 09 quad cab TRD off-road stays flatter and handles better around corners than my 08 reg cab prerunner. I want to improve my trucks on road handling since it spends most of its time cruising and towing BUT I don't want to alter the ride height. I've been lurking around this site for a few hours and it seems most of the suspension mods are focused on lifting and dropping. Does anyone make stiffer springs for my truck that are the stock height? How about rear sway bars since my truck seems to lack one?
    Also, can anyone tell me if my 08 model is affected by the leaf spring TSB or if they fixed the problem by then?
  2. May 3, 2009 at 1:11 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Well your best best is a pretty expensive one. I don't no what its called but its a sway bar for the rear. Ill try and find the thread
  3. May 3, 2009 at 1:13 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    i was checking that thread out last night Hellwig makes a sway bar thinking about getting one myself
  4. May 3, 2009 at 1:13 PM
    DanGer
    THATS IT, thanks burg
  5. May 3, 2009 at 1:13 PM
    Burgman
    Stephen
    Ric VA
  6. May 3, 2009 at 1:14 PM
    DanGer
  7. May 5, 2009 at 6:44 PM
    sriley727
    Aiken, SC
    Bone stock
    Thanks for the info, gentelmen. I think I figured the rest out myself. Hellwig EZ-990's will stiffen up the rear and will fix the heavy load problem along with the overpriced sway bar (I used to get those things for my Mustangs for like a 100 bucks or so). And a set of 2" id Swayaway coilovers on the front set at the stock ride height will give my 650lb springs compared to the stock 445lb. And the best part...no change in ride height! :D
