want more lift!
Discussion in 'Suspension' started by quicksilvertacoma, Apr 11, 2009.
  1. Apr 11, 2009 at 7:48 AM
    quicksilvertacoma
    quicksilvertacoma [OP] Well-Known Member
    Harlingen, TX.
    08 Reg. Cab Tacoma 4x4
    NA
    I just put a level lift on my 08 taco which picked the front up a little over 2'', but i still want more hight! any recomendations on what i can at to the level lift to maybe get another 2'' of lift all the way around?
  2. Apr 11, 2009 at 7:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you want to go taller than 3", your gonna need to invest in a drop bracket lift.
  3. Apr 11, 2009 at 7:58 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Just get some 884 or 885 coils. Then you will gain another inch up front. 3" total then.;)
  4. Apr 11, 2009 at 7:58 AM
    quicksilvertacoma
    Harlingen, TX.
    NA
    what does that consist of?
    any recomendations if i dont want to go more than 3''?
  5. Apr 11, 2009 at 8:00 AM
    quicksilvertacoma
    Harlingen, TX.
    NA
    where can i find those coils?
    do you think an add-a-leaf in the back would go good with that?
  6. Apr 11, 2009 at 8:01 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Those are just a new set of coils for the front. They just replace your stock ones.;) Like chris said, anything really over 3" is going to cost you a pretty penny.:( I think theres some 4.5" lift kit but its like $2100!!!:eek:
  7. Apr 11, 2009 at 8:02 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Heres a link. This is where I got mine from.
  8. Apr 11, 2009 at 8:03 AM
    quicksilvertacoma
    Harlingen, TX.
    NA
    WOW!!thats way over the budget! and i dont want that much lift, i just want a total of about 3''...so those coils sound pretty good...you think an add a leaf would be good in the back?
  9. Apr 11, 2009 at 8:04 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah that would be perfect. That is what setup I have. 885's up front and rear AAL's. Look at the website and get the BEST SELLER kit for $299.99. That will work out real well.;)
  10. Apr 11, 2009 at 8:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Also, Something to think about, the OME 885's will make the ride on your regular cab much more stiff.
  11. Apr 11, 2009 at 8:06 AM
    quicksilvertacoma
    Harlingen, TX.
    NA
    sweet man! thanks! and did you install it yourself? what am i in for?
  12. Apr 11, 2009 at 8:09 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    No I actually had a shop install my stuff because I replaced all four shocks, installed the front coils and rear AAL's, put on new upper control arms, got my wheels and tires balanced and mounted, and did an alignment.:eek: So a handful of stuff in one day.
  13. Apr 11, 2009 at 8:20 AM
    quicksilvertacoma
    Harlingen, TX.
    NA
    oh i see...well thanks alot man im def. gonna keep this set up in mind!
  14. Apr 11, 2009 at 8:21 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah no problem. Gook luck!;)
