Want OME coil springs, but already have Bilstein 4600 shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by JellyBeans, Jul 9, 2018.
  1. Jul 13, 2018 at 11:51 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Who's "they"??
    5100's have always been adjustable. That's the 5100's defining characteristic.
    A lot of people go with the stock coils to save some money. I did. Ideally, you'd get a longer spring, then make sure you set the 5100s at the "stock" height setting (let the spring do the lifting), but to save some cash, a lot of people keep the stock spring and set the 5100s higher (increasing the pre-load) to lift it.
  2. Jul 13, 2018 at 5:15 PM
    JellyBeans
    JellyBeans [OP] Active Member
    '95 4Runner SR 5 4x4
    '98 Tacoma SR 5 4x4
    5100
    Collapsed Length: 13.86" / Extended Length: 18.66"
    4600
    Collapsed Length: 13.7" / Extended Length: 18.4"
    Collapsed diff: 0.16" (~3/16"), Extended Diff: 0.24" (~1/4"), total diff in run 0.40" (~7/16")
    JBrandt, Not much of a difference in the shocks. I am going to try the 4600's, if any sign of problem will go out and get the 5100s and install them. This truck is my toy, not the daily driver, so not stuck.
    Should start a thread just on the truck. Bought with 193K miles, cleaned up, changed gear oils, sea foamed engine, going to clean MAF and throttle body this weekend, doing suspension, plan on pulling frame, sand blasting, powder coating, than filling with automotive foam, ...
  3. Jul 13, 2018 at 5:57 PM
    Tacomaman63
    Tacomaman63 Well-Known Member
    Stan
    2004 tacoma TRD 4x4
    step bars grille guard
    They are the people at Krawl Works
  4. Jul 16, 2018 at 1:28 AM
    Tacomaman63
    Stan
    2004 tacoma TRD 4x4
    There are 5100’s that aren’t adjustable that’s what’s on mine
