Want some 5100s?
Discussion in 'Suspension' started by DFPTaco, Oct 23, 2008.
  1. Oct 23, 2008 at 7:59 PM
    DFPTaco
    DFPTaco [OP] It's TACO time!
    Josh
    Woodland Park, CO
    14 DC SB SC TRD SPORT
    Rear diff breather relocate, BLHM, Scanguage II, Toytec Ultimate Lift set at 3" w/AAL, sway bar relocate, front diff drop, WeatherTech mats, TRD cat back exhaust, TRD Supercharger, KMC Enduros, 285/75R16, and full size spare.
    I'm thinking about getting a toytec 3" lift front and rear and they reccomend using the OME shocks over the 5100s right? So I have 3 questions.
    Has anyone used the toytec lifts with the 5100s?
    Is it a "no no" to use the 5100s with the lifts?
    If so, since the lifts come with coils already would anyone be interested in buying my stock coils with 5100s set at 2.5"? I have only had them for a couple months. What would be a reasonable price for those?
  2. Oct 23, 2008 at 8:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Many people have used the OME springs with the 5100 shocks. I have heard the ride is fine. OME springs with OME shocks is clearly the better way to go, BUT, before you go and throw your 5100 rear shocks away, I have heard some people have pulled apart the OME rear shocks when off roading. Seems they had a weak weld at the bottom of the shock. OME has warrantied these shocks, but I chose the 5100 for the rears because of this. Just a friendly FYI. ;)
  3. Oct 23, 2008 at 8:07 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Let me know when you make up your mind on whether or not you're keeping them! :)
  4. Oct 23, 2008 at 8:09 PM
    GreySky72
    GreySky72 Lemon
    Gilbert, Az
    08, TRD Sport, 4x4
    I know of a few people out here in az running the toytec and 5100's I might actually swap out my revtek for this combination
  5. Oct 23, 2008 at 8:10 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I'm installing the ToyTec adjustable coilovers with 5100s up front tomorrow
  6. Oct 23, 2008 at 8:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i dont have the toytec lift per say....but i have ome 881 coils with billy 5100's on the stock setting, and they ride great!
  7. Oct 23, 2008 at 8:15 PM
    DFPTaco
    Josh
    Woodland Park, CO
    Are you getting the full 3"?
  8. Oct 23, 2008 at 8:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah, mine was only about a 2 inch difference, but all im saying is that you can run the 5100's on the toytec coils...just keep them at the stock setting(shouldnt have to preload those springs), and they should work fine.
  9. Oct 23, 2008 at 8:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    the 881's Will has are the "Medium" springs and, I belive, Only give about 2" lift. :)
  10. Oct 23, 2008 at 8:19 PM
    DFPTaco
    Josh
    Woodland Park, CO
    well, then that's what I'll do. I'll get the 3 inch coil lift and use the 5100's... THanks all! As always.
  11. Oct 23, 2008 at 8:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    correct!!:D
