Want someone to press new wheel hubs - East Valley
Discussion in 'Arizona' started by treyus30, May 14, 2024.
  1. May 14, 2024 at 8:01 PM
    treyus30
    treyus30 [OP] 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I've been dragging my feet so long on getting 4x4 hubs pressed in on my 1st gen so I can finish my 4x4 conversion. Also have spindle gussets to weld in which I'm 100% capable of but if it can all be done at once for a good price, even better.
    Anyone know someone who will do the hubs for under a couple hundred? I can always just remove the spindles first too. All parts are in my garage already
  2. May 14, 2024 at 8:42 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Could pick up a harbor freight 20T press for around a couple hundred too
    Toycoma2021 likes this.
  3. May 14, 2024 at 8:48 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Have that, but don't have all the dies, and I'm told that may not be enough force
  4. May 14, 2024 at 9:00 PM
    time623
    James
    AZ
    People use them for it for sure, it’s what Timmy Toolman used in his video on it. Might be a bigger issue for rust belt trucks. No personal experience either way from me though.
    I’d imagine after you get the dies and all that you’ll be pretty close to what a shop would charge anyway though. Hopefully someone has a good recommendation.
    I need to get mine replaced soon as well and have been eying that press to do it so I’m interested what route you take
    treyus30[QUOTED][OP] likes this.
  5. May 15, 2024 at 9:13 AM
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
    I have a 20 ton press . I've done them before on my trucks with that press (borrowed tooling). Are you going to manual hubs or ADD ? I can help and we can get dies made too because I'm going to be replacing mine in a month or so . I also have a Miller if you wanna burn them gussets here too. I'm off higley n southern. DM let me know
    treyus30[OP] and MR E30 like this.
  6. May 15, 2024 at 9:47 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Cool, sounds promising! You're only a few miles from me, Ellsworth & Broadway. I have an ADD front diff but the plan is to leave it always in the locked position unless it becomes a problem for some reason
  7. May 15, 2024 at 10:03 AM
    Milota95
    Qrampage
    B.F.E
    Driven Safely
    Nice, I have ADD in my 97 have the zip tie mod haha I just blew up the front diff last month up in oatman and I need to do my wheel bearings also so let's make it happen we can get two birds stoned at once
    I have a full 4wd swap to manual hubs that's why I was curious, let me know man I'm usually always home we can get a game plan together
  8. May 22, 2024 at 8:53 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You get you handled?
  9. May 26, 2024 at 1:17 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Are you able to??
  10. May 27, 2024 at 5:41 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Nah not yet. I was kinda asking for a shop, or more preferably a local enthusiast, I could drive it to. Was going to message Milota since nobody but me has worked on this since Brakes+ butchered my axle seal job almost a decade ago and cost my dad $1k, but still would be nice just to drop it for a weekend and have it done
  11. Jun 2, 2024 at 8:35 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    if you can hand the spindles to me with the parts I can do it. Give me a couple days.
    chrslefty[QUOTED] likes this.
  12. Jun 2, 2024 at 8:43 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    chrslefty likes this.
  13. Jun 3, 2024 at 10:19 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    I guess my concern was always over pressing the bearing. Thanks for sharing the tool.
  14. Jun 6, 2024 at 10:43 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    The trick to installing the bearing in the knuckle is freezing the bearing and heating up the knuckle. When you do that the bearing almost falls into the knuckle.
