Want to add oem 110v to my SR5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aromeo620, Mar 7, 2014.
  1. Mar 7, 2014 at 4:29 PM
    Aromeo620
    Aromeo620 [OP] Active Member
    Anthony
    Boston, MA
    Toytec 3" boss Coilovers with an AAL
    Tried to find a thread on this but I have a 2011 tacoma sr5 and wanted to add that oem 110v in the bed! Anyone know where I could get my hands on one or if it's even possible to install one?
  2. Mar 7, 2014 at 4:56 PM
    ffdan83
    ffdan83 War Eagle!
    Daniel
    Gardendale, Alabama
    Super White 4x4 XSP-X
    If you find out let me know. I would also like to add one to my Taco!
  3. Mar 7, 2014 at 5:33 PM
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    Subbed I would like to add one to our 2014 we just picked up
  4. Mar 7, 2014 at 5:37 PM
    cholland
    cholland Active Member
    California
    13 Access cab 4x V6 manual
    If you want the OEM parts I would try Camelback Toyota. They are one of the venders on here and offer a TW discount. Probably still have to figure out your own wiring though.
    The stock inverter is mounted under the center console.
    Personally I plan to use an aftermarket inverter. Then I can get something a little larger, maybe 800w if I want. Depending on size might have to mount somewhere else. Give myself an outlet in the cab somewhere and probably just use a standard outdoor socket, maybe with a cover inside the existing storage pocket. Instead of loosing half the storage space to the OEM setup.
    Run power to the bed with 12/3 SJO. Its like heavy extension cord, so it makes a nice self enclosed 110v wire harness.
  5. Mar 7, 2014 at 6:36 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Yeah, I think it is MORE difficult to try and put an OEM AC in like the TRD system. Easier to put a bigger inverter in under the driver seat, and a lot cheaper.
    Run some 6AWG direct from the battery with alligator clips. There's a grommet on the body near the driver seat you can pierce to run the 6AWG into the cab and an extension cord from your aftermarket inverter through the same grommet back along the frame into the bed by drilling a hole at the rear of the bed (sans plug), then connect an AC female plug onto the extension cord. Pop a 3-outlet female plug on there so you can run multiple devices off of it. Thread some string or wire through the hole you drilled, tie it onto the extension cord and draw it up into the bed.
    Works great for me. I clip one alligator onto the positive batt terminal, the ground to the oil filter cup. If I disconnect them I put them into a ziplock bag behind the battery.
    It's actually much better than the OEM system because you have full wattage on demand anytime you please, just hook the alligator clips up.
    I think 800W is the max feasible with a single battery, there's just too much current draw if you go higher.
  6. Mar 9, 2014 at 2:48 PM
    Aromeo620
    Anthony
    Boston, MA
    So decided to go with a aftermarket one just gotta order it and figure it out but another question where could I get my hands on a Overhead Compass/Temp?
