Want to buy and trade third with stock gears.
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by diablo_Alex2777, Jan 20, 2014.
  1. Jan 20, 2014 at 9:50 PM
    diablo_Alex2777
    diablo_Alex2777 [OP] Well-Known Member
    Alejandro Gonzalez
    Mira Loma
    05 tacoma dcab Trd off road. 4x4
    Icon UCA's,coilover, Demello front,rear bumper All-pro 3in rear leaf spring Miler maker m8000 winch\ 33's coopers stt's Demello's skip plate 3 hellas 500's
    please delete thread.
  2. Jan 20, 2014 at 10:19 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    i got a front 8inch clam with 3.73s, I'm looking for 4.10s
  3. Jan 20, 2014 at 10:28 PM
    diablo_Alex2777
    Alejandro Gonzalez
    Mira Loma
    Sorry guys for my post. I have 3.73 gears on my truck right now. so i want to keep the rear the same 3.73, Figure i can help somebody with some $ and my third as a core to re gear their truck and they can help me with their stock third. So it has to be 3.73 ratio.
  4. Jan 20, 2014 at 10:32 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I'm confused on what you're trying to do here...
    Nvm I'm tired as hell ignore my post lol
  5. Jan 20, 2014 at 10:33 PM
    Scotty3
    Scotty3 Well-Known Member
    charley
    Elverta
    2011 4WD TRD Off Road
    too many to list
    I have a set of 3.73 front and rear I pulled out of my pickup at about 30K when i regeared to 4.56. These would need to be re set up in your diff's. Shoot me a PM if your interested.
  6. Jan 21, 2014 at 3:46 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I too am a bit confused about the final goal of going 3.73 to 3.73.
    To prevent more confusion, you really should let everyone know which rear end you are removing the third from.
    PK
  7. Jan 21, 2014 at 7:27 AM
    diablo_Alex2777
    Alejandro Gonzalez
    Mira Loma
    I have to regear mine. but im not changing the ratio. i dont have money to up grade to 4.88. so i want your diff with 3.73 ratio and you can use my third to re gear yours, plus i can give you some money. get it now?
    my rear end is 8.0 with e-lockers. sorry for the confusion.
  8. Jan 21, 2014 at 7:46 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I thought the stock TRD Off Roads w. e-locker came with an 8" rear? :confused: Did you swap at some point?
  9. Jan 21, 2014 at 7:52 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Wait, when you regear you change out the gearing to either a higher or lower ratio...there's no way you can "regear" and stay with the 3.73 unless you have messed up gears and need new gears only hence why you kept saying "you're regearing"
    Like my rear diff is geared to 4.56 now over the 3.73
    But I have a LSD diff (8.4)
    The e-locker diff is 8.0
    So if you want to regear to get some more power because of bigger tires...you're going to have to pay the money for both front and rear to either a 4.56 or 4.88 depending on what you want and it's pricy :anonymous:
  10. Jan 21, 2014 at 7:54 AM
    Manwithoutaplan
    ID
  11. Jan 21, 2014 at 11:22 AM
    diablo_Alex2777
    Alejandro Gonzalez
    Mira Loma
    Thanks. been reading other threads about re gearing. Im way of on the info. Thanks for you explatation now i get it.
