Want to change my gauge and A/C lights, need some help.
Discussion in '1st Gen. Tacomas (1995-2004)' started by NoTown98Yota, Nov 24, 2013.
  1. Nov 24, 2013 at 12:52 PM
    NoTown98Yota
    NoTown98Yota [OP] Whiskey Throttle FTW!
    Scott
    Reno, NV
    '98 Tacoma 3.4L V6 W/E-Locker
    -Leer shell with Yakima MegaWarrior -K&N FIPK -18" Magnaflow dumped after axle -Clear headlights -Blacked out bumpers, wheels, badges, mirrors, fuel door, door handles, tail lights, corner markers and turn signals -White LED gauge lights -SpiderTrax 1.5" Spacers -Pinch Weld Mod -Ultra Gauge -6 Switch Plate under single din stereo -Custom Battle Born bedside decals -Eibach 620# coils -Bilstein 5100's -Dakars -Toytec 1" Lift Shackles
    I really would like to change my gauges and A/C control lights to a white LED but I don't know which ones to buy and how many of them I need. It is in a '98 Tacoma. If someone could help I would greatly appreciate it. Thanks!
  2. Nov 24, 2013 at 7:34 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    There are some prior posts on this. I did mine a few months ago. Got them from superbrightleds.com. The hvac lights required some soldering. I don't like the way the hvac lights came out - there are bright spots where the leds are located - so lighting is uneven. But the dash looks good in white. Pretty easy to do.
  3. Nov 24, 2013 at 9:59 PM
    yoterdude
    yoterdude Well-Known Member
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    Aero Turbine 2525, Aero tip, AFE Dry Pro S filter, deckplate mod, TRS Morimoto Mini H1 projectors, TRS xBLed angel eyes, Vent visors, Blacked out tail lights, LED turn signals, 10w LED auxiliary reverse lights, 20in LED light bar, OTRATTW switches, LED interior lights, Blue needles, front Bilstein 5100s, Eibach coils, Bilstein 5100 rear shocks, OMD leaf spring mod, Trail Gear low profile bumper, Black grill, JVC KW-HDR81BT head unit, Husky Liners, 5% tint all round, 50% tint on windshield with 9 inch strip, front Wet Okoles, stickers, and a rubber ducky on the antenna :D
    I changed my bulbs to leds a while back and have love it ever since! It is four 194 bulbs in the back of the gauge cluster and two 74 bulbs in the hvac panel.
  4. Nov 24, 2013 at 10:52 PM
    NoTown98Yota
    Scott
    Reno, NV
    That is what I thought but wanted to be sure. Thanks!!! Where did you buy them? I also, noticed there are different kinds of wedge and bulbs? Any idea which are best?
  5. Nov 25, 2013 at 9:19 AM
    yoterdude
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    I bought mine from superbrightleds.com and I think the 360 degree bulbs are the best because the single leds leave uneven light. The leds I used also are dimmable despite what some people say that leds aren't dimmable. I used these in the gauge cluster..http://www.superbrightleds.com/more...led-bulb-6-smd-led-wide-angle-wedge-base/211/
    and these in the a/c panel..http://www.superbrightleds.com/more...led-bulb-3-smd-led-wide-angle-wedge-base/228/
  6. Nov 25, 2013 at 10:24 AM
    NoTown98Yota
    Scott
    Reno, NV
    Thanks a ton! Ordering them today!
  7. Nov 25, 2013 at 11:12 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    LED's are in fact dimmable and works with the dimmer swtich. Just make sure you get the 360 degree ones to illuminate the cluster properly and make sure to test them out before you put the cluster back in.
  8. Nov 25, 2013 at 11:44 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Am I missing something? Those dont like even close to the correct bulb...
    Op, when I get home today, I some pics of what I did. I cant get on Ebay to like you the lights I used, but if you give me a day or two, I have some left overs I can send you for free.
    Or do '98's use diff bulbs???
  9. Nov 25, 2013 at 11:54 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  10. Nov 25, 2013 at 12:04 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Looking at the link above, I did not use those bulbs as those bulbs on the link does not have a forward facing led. I used the ones on the link below. Also, I've gotten bulbs from superbrightleds.com and also off e-bay and Amazon but the superbrightleds are in fact that, brighter then the other brands.
    http://www.superbrightleds.com/more...led-bulb-5-smd-led-wide-angle-wedge-base/206/
  11. Nov 25, 2013 at 12:19 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  12. Nov 25, 2013 at 12:26 PM
    yoterdude
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    Those are the correct bulb for my 2000 and I doubt anything changed from 98 to 2000. I have had those bulbs in mine for a couple years now and they work great!
  13. Nov 25, 2013 at 12:31 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
  14. Nov 25, 2013 at 1:20 PM
    NoTown98Yota
    Scott
    Reno, NV
    The 6SMD LEDS that you posted seem to check out and match up on the vehicle light search on superbrightleds.com, I put in an order for them today and will post some pics when I do the install. Thanks for all the input!
  15. Nov 25, 2013 at 3:54 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Go easy on taking the cluster out as it needs some manipulating to get out. I remember not being able to get the dash bezel out as the vent kept snagging on something.
  16. Nov 25, 2013 at 4:27 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  17. Nov 25, 2013 at 5:44 PM
    ghs57
    Chops
    Catskill Mts. NY
    Nice write up. Wish I had seen it in July.
  18. Nov 25, 2013 at 8:42 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, I hate doing write ups. Mine are never good...
  19. Nov 26, 2013 at 10:00 AM
    yoterdude
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    I viewed your write up and it does appear that the bulbs are in different locations. The bulbs in yours are behind the a/c panel on the circuit board and 98-00 have two bulbs right behind the plastic cover. Good write up though!
