Want to fix rough rear end
Discussion in 'New Members' started by CaliTexmex, Oct 29, 2020.
  1. Oct 29, 2020 at 6:51 AM
    CaliTexmex
    CaliTexmex [OP] New Member
    2000 toyota tacoma
    Leveling kit
    Hey everyone looking to fix ride in the rear end of my 2000 Toyota tacoma pre. Have 2” blocks with oem shocks. Wanting to know if the correct way to fix the ride. After research i was planning on a 1.5” add a leaf w/ B8- 5100. Is there a better set up or anything i should add its my daily driver.
    buckhuntin-tacoma likes this.
  2. Oct 29, 2020 at 6:56 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    AAL will stiffen the ride
    Shocks will cushion the bumps
  3. Oct 29, 2020 at 7:15 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    First off, its a truck. By nature the ride will be a bit stiff in the rear. It won't ride like a 70's land yacht.
    The truck will likely have an "improved" ride when it is loaded to about 1/2 capacity with weight. The springs support the truck.
    Once upon a life ago, I had a GMC 2500HD. It had a fairly "hard" ride when unloaded, but put 3800 lbs of landscape rock in the bed it would ride like a 70's land yacht.
    Shocks only control the "bounce" of the truck, no support.
    I'd suggest to not add any springs. You could change the shocks for a different damping rate.
  4. Oct 29, 2020 at 7:34 AM
    CaliTexmex
    2000 toyota tacoma
    Leveling kit
  5. Oct 29, 2020 at 8:18 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    CaliTexmex[OP] likes this.
  6. Oct 29, 2020 at 10:46 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
