Want To Go Back To Stock, Need Some Info.
Discussion in 'Suspension' started by STOCKTRD, Feb 14, 2012.
  1. Feb 14, 2012 at 8:19 PM
    STOCKTRD
    STOCKTRD [OP] Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    Ok Ive been doing some research and I am alittle unsure and I need some info.
    I might be picking up a 99 Tacoma TRD Off Road 4X4 V6 Extended Cab.
    The previous owner replaced all of the factory Bilsteins with Monroe OE Spectrums. So first thing I want to do is get the Monroes off and replace them with factory Bilsteins. Heres where I start getting confused. I dont know if the part numbers for the Bilsteins are for the TRD Off Road. Ive read that the replacement shock that Bilstein makes are valved diffrently than the stock Bilsteins Toyota shocks. Is this correct?
    Or, should I just upgrade to the 5100/5125 set up from Down South to replace the factory shocks that will let me keep stock height?
  2. Feb 14, 2012 at 8:28 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    replace them with the 5100s.
    after riding in a truck with the blue/yellow bilstein HDs, then mine with 5100s...
    the ride is much better
  3. Feb 14, 2012 at 8:41 PM
    STOCKTRD
    In Traffic
    CustomTacos Mafia!
    So can I run the 5100s all around or 5100s up front and 5125s in the rear?
    Yeah I know this has probably been asked so many times already.
  4. Feb 14, 2012 at 8:42 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    5100s all around iirc
  5. Feb 14, 2012 at 8:42 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    before you order the shock, give DSM a call; theyll let you know what you can/cant fit according to your needs. They've helped tons of our members here before :thumbsup:
  6. Feb 14, 2012 at 9:06 PM
    STOCKTRD
    In Traffic
    CustomTacos Mafia!
    Yup, Ive already sent them a few emails.
  7. Feb 14, 2012 at 9:42 PM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
    X2
  8. Feb 15, 2012 at 7:00 PM
    STOCKTRD
    In Traffic
    CustomTacos Mafia!
    So I did a little more research and as soon as the deal goes through on the Tacoma Im putting an order inot DSM for the 5100/5125 setup. Thankd for the help.
