Want to have phone maps turn-by-turn while listening to FM Radio
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MicrowaveKane, Jun 25, 2018.
  1. Jun 25, 2018 at 1:25 PM
    MicrowaveKane
    MicrowaveKane [OP] Member
    I just got a 2018 Tacoma with Tech Package and am learning to use the head unit with my phone. I don't listen to music on my phone, but want to use it for maps (since the Entune maps is not great compared to Google Maps).
    I want to plug my iPhone X into USB and mount it to use for Maps. But, as far as I can tell, you can only get the phone audio (turn by turn directions), by switching the source to the USB Audio. Is it possible to listen to the FM source and have the direction audio cut in like it does when using the built in navigation?
    If not, then how are you guys handling music, etc? Do you connect the phone and just use streaming music to keep everything from the same audio source? Do you just listen to FM or XM without hearing the phone?
    Is this possible?
  2. Jun 25, 2018 at 1:30 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    No can do. Have to consolidate your source to get both at the same time. Music and maps from headunit. Music and maps from phone. Can't mix and match.
  3. Jun 25, 2018 at 2:13 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    I think you need to stream your FM stations from a phone app. That way both audio sources come from your phone, and might be able to place nice with each other.
