Want to increase GVWR... Need opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomadre, May 28, 2012.
  1. May 28, 2012 at 8:55 PM
    tacomadre
    tacomadre [OP] Well-Known Member
    Jose
    SoTex
    06 PreRunner SR5 Speedway Blue
    I have an 06 Taco TRD that has a GVWR of 5500lbs but need to get it a little higher. I've read about the turbos and cai and exhaust but what will be the best thing to gain about 500lbs of GVWR? The turbo is a little more than I want to spend and my truck gets about 9 mpg when pulling my boat. Also, is there a good tranny cooler that soemone can recommend? :):)
  2. May 28, 2012 at 8:56 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Toyota Tundra iForce 5.7
  3. May 28, 2012 at 8:59 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Airbags?
  4. May 28, 2012 at 9:03 PM
    tacomadre
    Jose
    SoTex
    I just realized I posted this thread in the wrong location. Airbags huh???
  5. May 28, 2012 at 9:04 PM
    PLC721
    Patrick
    Chandler, Az
    what about the TRD S/C if you need more power? a CAI won't do much for you, or possibly a re-gear?
  6. May 28, 2012 at 9:07 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    my trd sport came with a transmission cooler, maybe grab the toyota one if yours doesn't have one..
  7. May 28, 2012 at 9:10 PM
    tacomadre
    Jose
    SoTex
    It may just have one (tranny cooler) I havent checked to be honest. What about headers & exhaust? Will they be effective in getting better MPG?
  8. May 28, 2012 at 9:11 PM
    PLC721
    Patrick
    Chandler, Az
    headers maybe if you don't mind the sound, but exhaust....no
  9. May 28, 2012 at 9:14 PM
    tacomadre
    Jose
    SoTex
    it doesnt look like mine has the tranny cooler. I only see the condenser in front of the radiator
  10. May 28, 2012 at 9:15 PM
    PLC721
    Patrick
    Chandler, Az
    thats the tranny cooler right guys?
  11. May 28, 2012 at 9:16 PM
    tacomadre
    Jose
    SoTex
    its pretty big if it is a tranny cooler
  12. May 28, 2012 at 9:20 PM
    PLC721
    Patrick
    Chandler, Az
    oh never mind I'm an idiot lol
  13. May 28, 2012 at 9:23 PM
    tacomadre
    Jose
    SoTex
    It's all good. I wish it was that big then I wouldnt havee to worry about my tranny heating up. Guess I'm looking for a tranny cooler for starters.
    Does anyone else get this ridiculous (9mpg) gas mileage when towing?
  14. May 29, 2012 at 2:59 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    All trucks get reduced mileage when towing. We are missing a lot of required information though. What size is the boat you're towing is the main thing. What is your main goal. better mpgs, better power, ability to carry more of a load.
    Better mpgs/power. Headers, intakes, chips, etc will have a minimal impact. $50-$500 a piece. a turbo or super charger will help with the power which "should" improve your mpgs, but most people can't keep their foot of the pedal. $1-$2000 Gears. You can regear the differential for better low end power and mpgs while towing, $4-600
    Better handling with a load. Suspension will help handle the load, but should not be used to increase the weight capacity. You still have weak links not meant to handle the extra weight, wheel/axle bearing, brakes, bushings, etc. $200-3000
  15. May 29, 2012 at 6:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You can't increase a vehicle's GVWR, you can only make modifications so the truck better handles loads within it's capabilities. If you tow frequently, you definitely should have gotten the factory tow package. It comes with a transmission oil cooler and a supplimental engine oil cooler along with a larger alternator.
    Air bags are a good way to beef up the rear suspension and the great thing about them is they are adjustable. The bad side is they limit off road articulation (if you off road at all).
    A good weight distributing hitch will help distribute the trailer's weight to the front end also and can make towing feel a little easier.
    As far as the MPG, best thing you can do is try to keep your foot out of it but it seems to be pretty common that the Tacoma gets crap mileage while towing.
  16. May 29, 2012 at 6:36 AM
    tacomadre
    Jose
    SoTex
    lol, I thought about it but the Tacoma is planty capable. The boat is a 20'6" Tahoe Q6. I think that I'll get the air bags for starters and then the coolers.
  17. May 29, 2012 at 6:46 AM
    bubbagumps
    bubbagumps Well-Known Member
    If you're looking for higher gvwr, you need to go fullsize. It will be a lot cheaper to trade up to a tundra than mod out a tacoma.
    With the deals they are offering now on well equipped tundras, I would consider it if hauling is a big concern. In fact, you can get a new 5.7l tundra dc, well equipped, for less than some tacoma trims.
    Also, believe it or not, you will get better towing mpg with a 5.7 tundra, even though non towing mpg is worse. You will cruise at lower rpm with the bigger engine when towing. The taco will be taxed and heated when pulling that kind of weight. You will be lucky to get 12 hmpg, more like 10 if its hilly. You can get consistent 13-15 mpg when towing with a 5.7 tundra.
  18. May 29, 2012 at 7:47 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    How much does it weigh? The V6 with the tow package is rated at 6500lbs.
  19. May 29, 2012 at 8:32 AM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    If power had any effect on GVWR, you would think that the 6cyl would have a higher GVWR than 4cyl. This is not the case. In fact, since the 4cyl weighs about 100 pounds less than the 6cyl, it actually has an extra 100 pounds payload capacity before hitting GVWR.
    The process of actually increasing GVWR would require certain engineering certificates, and having them registered with your local motor vehicle authority (if yours would be willing to accept them). This is practically not an option. The reality is that you could alter the reasonable weight limit through reinforcing the frame, heavier springs, full floating rear axle, etc., but this wouldnt have any effect on the legal limitations.
  20. May 29, 2012 at 8:38 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    BTW: what does the truck's GVWR have to do with fuel efficiency or hauling a 3500 pound boat?
