Want to install a 12V relay for a transmission cooler fan.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JohnDeere630, Aug 1, 2024.
  1. Aug 1, 2024 at 8:39 PM
    JohnDeere630
    JohnDeere630 [OP] Well-Known Member
    Gary
    Gray 2023 Tacoma SR5
    I bought all the stuff, and plan to install my transmission cooler at my next oil change. I'd like to mount a relay for the fan somewhere near the fan itself, and run a multi-conductor wire into the cab that will connect the oil pressure sender and the fan relay to a unit inside the cab. Can anyone advise the best place to tap a keyed 12 volt supply good for around 10 amps close to the radiator? I'd hate to reinvent the wheel if someone has already done this.
  2. Aug 1, 2024 at 8:41 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    OnHartung'sRoad likes this.
  3. Aug 1, 2024 at 8:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Toyota didn't give you any extra room to add 10 amps to an exiting circuit.
    You need to use a relay and go from the battery. The battery is right there anyways.
  4. Aug 1, 2024 at 8:48 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yep, I would tap off an ignition based source to trigger a relay that connects your fan directly to the battery.
    EDIT: And have fuses.
    TnShooter[QUOTED] likes this.
  5. Aug 1, 2024 at 10:32 PM
    JohnDeere630
    Gary
    That's what I was afraid of. I wanted a keyed supply, but I suppose that may be more trouble than it's worth. I'll probably wind up pulling a low-amp keyed feed for the relay coil. I just figured that someone smarter and more experienced than I had a more elegant solution.
  6. Aug 1, 2024 at 10:37 PM
    JasonLee
    15 TRD OffRoad
    On an older vehicle with much simpler electronics you may have gotten away with doing the simpler solution. But with your 3rd gen, I wouldn't chance it with all the computers and circuits talking to each other.
    TnShooter likes this.
  7. Aug 1, 2024 at 10:39 PM
    JohnDeere630
    Gary
    Excellent point.
  8. Aug 2, 2024 at 11:04 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I purchased a fuse distribution block and a relay block. Mounted neatly between the battery and firewall. You can bundle relay control through the already existing grommeted cab / engine compartment. Once complete you can use open switch spaces or mount an new switch panel. There are also monitoring devices that use the port. Then switch on the fan when temperatures indicate
  9. Aug 2, 2024 at 12:19 PM
    JohnDeere630
    Gary
    Do you have some pics and links to what you used?
  10. Aug 2, 2024 at 1:57 PM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
  11. Aug 2, 2024 at 11:11 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    OK, I'll ask the $64,000 question. Why are you adding a fan in conjunction with a transmission fluid finned cooler? I ran a 20,000 lb. cooler at the very front of the vehicle towing a 6,500 lb. trailer with no cooling problems. What makes you think you actually need an additional fan to circulate air through the cooler? What do you plan on using to monitor the ATF temperature?
    What I'm saying is you may be doing more work than is necessary.
    If/when I get back into towing, I may install something like this:
    Fluid Control Thermostats (derale.com)
    Currently I have uninstalled my cooler.
  12. Aug 3, 2024 at 2:52 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    As mentioned already, I’d also use the battery to power a 10amp accessory, and this is what I did- I installed fans like these shown below to cool my AC condenser, especially when 4-wheeling or stuck in traffic in hot weather:
    https://www.amazon.com/dp/B0C9BY9G4G
    And used this gang panel switch to manually control it along with other lights and accessories:
    https://www.amazon.com/dp/B088TG9W2M?ref=ppx_pop_mob_ap_share
    The switch panel is mounted above my dash and has a control box I mounted
    on the fire wall. Even though the box has built in relays, I just used those to control other relays mounted near the fans and other accessories like my ditch lights by using small gauge wire and fed them to power the relay coils instead of having to put heavy gauge wires through the fire wall.
  13. Aug 3, 2024 at 3:40 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
  14. Aug 3, 2024 at 6:01 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    I kept heavy gauge wiring in the engine bay also and only sent control wires through the firewall
  15. Aug 3, 2024 at 6:21 PM
    JohnDeere630
    Gary
    Yes, that was my plan as well. Thank you all for the links and feedback.
  16. Aug 3, 2024 at 6:24 PM
    JohnDeere630
    Gary
    I guess that's a legit question. I don't know that I NEED it, but I do occasionally have cause to haul a trailer over the Divide, and I don't want to toast my transmission. It's already running ~180 - 200 degrees on a hot day with no trailer.
