Want to Install Courtesy Foot Well Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 95SLE, Aug 21, 2009.
  1. Aug 21, 2009 at 5:13 AM
    95SLE
    95SLE [OP] Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    My base Tacoma does not have foot well lamps. Does anyone know if there is a preexisting connector or the wiring I need to tap into? I would like the lamp to go on when the door is opened.
  2. Aug 21, 2009 at 5:31 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
  3. Aug 21, 2009 at 6:23 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Veccster:
    Thank you for the reply. I read the threads you provided and one that was referenced in that thread and did not see what wires were used to make the LED's operate when the door is opened. It seemed that the referenced thread used a switch and the orher thread use a circuit that provides lights for the radio.
    I need to find a wiring diagram for the 09 bur have not been too sucessful. A set of tech manuals is $435 which is way to much IMHO. I thought that GM's manuals at $225 were expensive.
  4. Aug 21, 2009 at 7:03 AM
    Veccster
    Veccster bass turds
    Eric
    2009 DC V6 TRDsport
    You're right...I haven't seen it done to come on with the doors open. You need to find the dome light wire.
    I'm sure it's accessible in several places but only a wiring diagram would say for sure. Chris4x4 has sent them to me before (for the wires operating my windows). Not sure where he gets them.
  5. Aug 21, 2009 at 8:31 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Once I finish this I will do a write up. However this may take a few weeks. I have other family priorities at the present time.
  6. Aug 21, 2009 at 9:12 AM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    i didn't include how to get the footwell lights on when the door is opened in my thread but it can be done by tapping into the dome light. just make sure you get LEDs that can be dimmed or you will be sol.
    EDIT: i am a re-tard i did not read anything above this post nvm
  7. Sep 7, 2009 at 10:08 AM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    Any updates on this topic?
  8. Sep 7, 2009 at 10:15 AM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    If you want them to come on with the door then why don't you just tap in to the dome light wires?
    EDIT: sorry i didn't read the above posts either.
  9. Apr 1, 2011 at 7:51 PM
    tacomian devil
    tacomian devil Canadian member
    LA Canada
    SexyBlack TRD Sport DC LB w/ heated leather
    Nerf bars, Alum Knight Grill, CatBack Exhaust, Bakflip G2 HD tonneau, Dynolock electric tailgate lock, Webasto TVS 940 ST 2 panel electric sunroof, VIPER 5901 Alarm/Remote start, 3M FX PREMIUM 5% tint on back seat & rear slider, 15% on front windows. Retrofited Morimoto Projector headlights in smoked lamp housings with 35W 5000K bulbs lit by Denso slim ballasts, Gatling Gun shrouds capped with 100mm Cold Cathode Fluorescent Light rings.
    Has this project been completed by anyone? I want to connect some LED floor courtesy lights under the front dash and maybe under the driver and passenger seats also, but I can't find any DIY thread that has them hooked up with courtesy cabin lighting.
    I would settle for floor courtesy lighting that was activated only when doors are open, but I would prefer a switch option that would also allow me to turn them on/off similar to the cabin light options.
    Is this a DIY for a non-electrician?
  10. Apr 2, 2011 at 5:46 AM
    28Gauge
    Brian
    Grapevine, TX
    06 PreRunner SR5
    X2
    I'm no electrician, either. I would love to see a write up soon!
  11. Apr 2, 2011 at 7:50 AM
    KevLot17
    KevLot17 Well-Known Member
    Kevin
    Pennsylvania
    '10 Blacked Out TRD Sport
    Debadged, Toytec Ultimate Lift, Banks Monster Exhaust, AFE Pro Dry filter, Black Grillecraft grille, Flat Black background headlights, Red Blinkers and markers with alternating turn signal mod, Krypton Bulbs 6000K Headlights and Fogs, Fog Light anytime Mod, LED interior lights with map light mod, AVS Black Taillight Covers, Tinted Windows, WeatherTech Digital floor liners.
    without searching for the how-to...i would assume you could just tap into the door pin switch by taking the kick plate and B pillar trim off, unboltid it from the pillar, and feeding te wire back into the cab... that would make the lights go on when the door is opened correct? far from an electrician also.. but just something that popped into my head..
  12. May 23, 2011 at 3:29 PM
    ryguy
    ryguy Well-Known Member
    Riley
    Central California
    06 Silver Double Cab 4x4 TRD Sport
    I will try and find a wiring diagram for you for the dome light, and or do a write up myself becuase i have been wanting to do this and havent been able to find anything.
